greater manchester
location sound, mostly tv
3,688 profile views
Coolest Piece of Equipment You Own?
Lancashire soundie replied to sciproductions's topic in Equipment
I work on the World Rallycross Championship as soundman and this weekend had an interesting diversion. The job is fairly simple, a robust SQN (no time to turnaround separate audio files etc) plugged into a camera for VT stuff, couple of radio mics, press conferences, supplying wireless mics for other crew, etc. Nothing remarkable but there's a lot to do each weekend. This weekend we had a fully electric rallycross car make it's debut on the track, doing passenger laps. Our presenter was one of those passengers, so in addition to a bunch of Gopros and track cameras covering it, I volunteered to try to get some driver/passenger audio in the car. Budgets are such that I don't include personal recorders in the kit, so I put the SQN in the back (only place with any room) of the car, strapped it to the roll cage, and used it to feed a Tascam DR-70D which is something I chucked into the kit as a general purpose recorder that people could use to grab audio of "whatever". I did all this in the morning, knowing the car would be out a few hours later. I had other stuff to do in the meantime. The only place in the car I could put the SQN was on top of the car's 2 invertors, which I'm told are about 400V. The Tascam was on top of the SQN, about the height of the SQN from the invertors. Anyhow, the car duly made its way onto the circuit and I went over to mic the presenter (Lectro radio). There was hardly any time, so I didn't mic the driver, I just checked everything was set, pushed record, locked the controls on the Tascam and let them go. The team was getting a bit anxious for the car to get moving, as track time was limited. When I checked later on, the DR-70D had recorded 4 2-second-long files of nothing. One file had a quick burst of static. That was it. It wasn't a critical issue, nobody was bothered (it was a last minute decision to try to get something), and the Gopros picked up his shouting and screaming anyway (this thing is a rocketship). It's a social media piece so not on the main broadcast. The Tascam has never done that before, so I can only assume it was the car's electrical systems that caused it to fail. I haven't tested it since the job, it's in a flight case now on it's way to South Africa so it'll be a few weeks before I can. Anyone had a similar experience in an electric car?
Sennheiser MKH60: Any reports of counterfeits?
Lancashire soundie replied to ronmac's topic in Equipment
Probably referring to reflections off hard surfaces, such as booming in a concrete room. I've used an MKH60 for 20 years now, never been serviced, still in perfect working order. Don't think I'll ever change it tbh, it's a workhorse. -
I think I'd save the TXs for something else. The G3 is perfectly good for it's price point (I have a couple for a particular job), but it isn't really suitable for a boom (IMO). Keep them handy for the odd occasion you'll be asked to provide a radio stick mic or something. But if you insist, you could power the mic with this - http://www.pinknoise-systems.co.uk/ambient-ump-ii-universal-mic-power-supply.html
DPA slim cable getting stiff and brakes
Lancashire soundie replied to Lauri Laagus's topic in Equipment
I wouldn't have accepted such a refusal. I would have insisted on a refund or a date in court. The EU gives you good, solid protection against such behaviour - a microphone cable should last at least 5 years IMO. -
I need an answer for a question which may come up soon. Possibly up to 4 presenters on handheld stick mics, feeding 2 radio receivers on the back of an RF camera on an OB. Is it possible to feed those 4 channels into the camera (no, I don't know the camera model yet) and have them fed over the digilink via SDI, to the truck, so the audio mixer can control the levels independently? Or I give the audio assistant following the RF cameraman a simple mixer and 4 channels of radio, and have him mix them and give the camera a mono feed.
Int'l Traveling from u.s. with gear for personal use
Lancashire soundie replied to osa's topic in Equipment
Take some cables so you can plug whatever you bring into consumer devices, mainly a phone or a GoPro. If you turn up with gear that terminates in XLRs you're going to have a hard time explaining it's for personal use only. Make sure you have something like Filmic Pro on your phone. FWIW I have never once been stopped in airport customs. I once had to do a Carnet from Norway and the customs officials in the UK looked at me like I was an alien. -
Interesting to know, I was considering buying one of these next year to replace an SQN on a job where my kit travels without me. I guess I'll look elsewhere now.
> zaxnet worked on this devices some month ago with the previous owner Are you certain he wasn't adding Zaxnet via another device, like an IFB200?
Primarily, audio quality. The SR receivers with smqv transmitters (for example) will sound much clearer with loud noises and the like. They'll essentially sound as though you've got an invisible wire between you and the microphone. They're very reliable too and as Jim has said, very, very well built. My tx's live in the leather cases they came in (some people don't like those) and they're as fresh as the day I bought them. As for range, you'll find they go further than the G3s by a long way. I've shot diagonally across the length of a football pitch with the presenter's tx in his front pocket on several occasions and got a reliable, usable signal. That's on 50mW with just the whips. Obviously that was in an empty stadium, but you see my point. Indoors they work extremely well, although I have had occasions inside reflective buildings where the receivers have got a bit confused. The G3s are a very good system (I have two) but the Lectros are far superior. If you're buying new, may I also suggest you look at Zaxcom's gear with internal recording and remote control of gain/frequency, and the new Audio ltd stuff which also does internal recording. One more thing - the Lectros use digital technology, there's a 3.5ms delay in the audio chain. You need to consider that when mixing with non-delayed sources like microphones.
I'm using this: http://www.pinknoise-systems.co.uk/ambient-quick-pole-qp-480-boom-pole-105-350cm.html It's very well built and has enough reach for pretty much anything. This after sticking with a 2m Panamic that's still in superb condition after nearly 20 years of use. I'd stay with Ambient, just get a shorter one.
The plastic tubes Rycote are selling as part of this kit aren't something they've designed and manufactured for themselves. They're fairly standard screwpack postal tubes, I've had bicycle components arrive in some.
Buy one of the LMC units and chop some of the plastic off with a tiny hacksaw or a hot knife. Or a file. I doubt you need the clip to completely surround it, it only has to grip it lightly. Another option is to use a Tram tr-50 vampire cable clip, they hold microphones surprisingly well.
