zerascal
    France
    post production field recording
1,548 profile views
  1. Yeah, I'm not surprise, like many 2.4Ghz devices, they are just good for working without cables but very close and in line of sight of the camera
  2. Anyways,because 2.4Ghz inside, I don't see the necessity to have 4 channels if any physical barriers (wall, doors, bushes, human bodys) between the Tx and the Rx generate drop outs like early consumers report on Deity FB group… It seems to only working good in direct line of sight, with the Tx in the front pocket... 👿
  3. zerascal
    nova!
    yep no problemo, you choose mono or poly before recording and you can change it in zaxconvert or Wave agent after recording
  4. or you could buy the awesome Sma whip swivel jointed antenna from Audioroot: https://www.ebay.com/itm/UHF-SMA-WHIP-SWIVEL-JOINTED-ANTENNA-450-900-MHz/221539398514?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20180816085401%26meid%3Dad16a4f588304a1f8c1668a7f47ee662%26pid%3D100970%26rk%3D1%26rkt%3D2%26mehot%3Dpp%26sd%3D221539398514%26itm%3D221539398514&_trksid=p2481888.c100970.m5481&_trkparms=pageci%3Adace4bfe-587d-11e9-a9d8-74dbd1807197|parentrq%3Af331bf7b1690ac3df2c8b821fff66ea2|iid%3A1
  5. Zaxcom maxx can do that without problem: iso untouched+ recording stereo out changing width with mid fader
  6. Hello, Did anyone had a chance to try the new KSHRN3S – Stingray Harness Small and to compare it with the regular one? I'm 1.75 meter , middle weight (70kg) and wonder which one to take? I saw the difference between them are the shorter exosqueleton and smaller shoulder straps. Cheers
  7. Nice takes Jason I really like my AT BP4029 MS too, it's a great MS mic for an awesome price. I use it on doco & run and gun
  8. Yep Martin, all that could and should be done in post, you just need to record Mid on card 1 and Side on card 2. The method I described with OUT1&2 is to deliver a stereo mix (if no post for example) that couldn't be change or adjust later. Indeed SD has a setting for doing that.
  9. What martin wrote for listenining encoded MS, plus make the same on Main OUT 1&2 matrix: mic1 (mid) mic2(side) to OUT1 mic1 and mic2 (phase reversed) to OUT2 and then record card3=OUT1 and card4=OUT2 to record decoded MS stereo signal. So you'll have encoded MS on card 1&2 (mid on1 and side on2) and decoded stereo signal on card 3&4
  10. it was a no post project and as long as have a notch option, make it useable
  11. I hadato rip off a 8000hz lightning hiss today and it was a pita with my maxx, much too long when director went to shoot itw on the fly... A good option would be to have the possibility to enter a frequency around suspect noise with keyboard and then affinate properly with dial, or another key to allow 100hz move, just sayin...
