About Martin Jelovsek
- Birthday 08/25/1980
Slovenia
I do a lot of location sound mixing for commercials.
2,668 profile views
Zaxcom Fusio folder lost from the primary card
Martin Jelovsek replied to mirko's topic in Equipment
How old was the card? I had problem with one card that I “used too long” ... Try the software Howy recommends if it can recover the files for you. Martin -
New development ... I guess I have gremlins here as there is no other explanation ... Now everything works !!?? No idea why and what is more worrisome for me is that I do not know why now everything works but on Saturday did not ... Martin
John yes I have tried everything I could think of ... The funny thing is that if I use the same cable and use it to jam slate and then use slate as master and jam the recorders back ... it works ... with the same cable ... It just does not work between the recorders ... I tried in both directions ... Martin
Well the first problem is that I do not get the signal in ... in the TC page the top TC is static and is not running, but if I connect for instance slate I am getting the signal in ...
Hi John, thank you for warning but that was actually one of the first things I checked ... Martin
Hi guys,I have just encountered 2 strange problems regarding TC with which I am going slightly mad.1. - I wanted to connect two recorders together (one is Deva 16 the other Fusion 12) so I could record with the same TC but I cannot get the TC signal from one recorder to another.But if I use the same cable and connect the external slate - Denecke TS-C I get the signal in ... And if then I use the same cable (just turn it around) and use the output from the slate to the device (Deva or Fusion) I get the TC signal into the recorder.I just cannot get the signal from one recorder to another.2. Then I wanted to connect the TC box (I have Timecode Buddy Pulse) so recorder would be master and then would jam the external box. I do not get any signal out of the recorder ... Again I tested it with the Denecke slate in between and everything works... Now I suspect that something is going on with the signals (could it be that it is too hot?) but I have no idea if that is the case ... Martin
Martin Jelovsek changed their profile photo
Hi guys I hope that you will be able to help me as this is bugging me for couple of days now The other day we had a discussion with couple of friends and one of them asked me a question on what type of microphones and headsets did the first astronauts use for communication? Was it dynamic, electret, condenser ... It got me curious and actually I cannot find the answer to that question ... If anybody here has any idea what was it used at the time? And who was developing them for them? Thank you for the help Martin
Shooting commercial and it got crazy Sent from my iPhone using Tapatalk
Guardian of the sound Sent from my iPhone using Tapatalk
On shoot of Slovenian motion picture Sent from my iPhone using Tapatalk
Thank you, Jeff. I am really proud of this picture Martin
Well as we were finishing shooting in Liauing Museum in Austria I found myself in empy set / room so I kind of did this picture that I consider ART Martin
Well it was actually taken a month ago on a set when I went to record some ambient sound of the area ... Location: near Pag on island Pag, Croatia Martin
USB serial cable for ZAXCOM QRX
Martin Jelovsek replied to Martin Jelovsek's topic in Do It Yourself
Better later than never ... @osa I would recommend it to check the firmware as with me it started working after update and now it works without the glitch. The only thing is be sure to mark the cable-ends (which one is IN an which one is OUT). I did not do it with one cable and then it took me awhile to figure it out ... Martin -
Yosemite and disabling USB drives
Martin Jelovsek replied to Martin Jelovsek's topic in Macs... and the other computer
@soundchris I will do the tests next week as I got couple of projects and right now I do not have time for this. I will post the results Martin
