Italy
I'm a mercenary worker
1,639 profile views
Hello I use Zaxcom Fusion for many years and yesterday for the first time I lost an entire folder from the primary card. I had formatted the card regularly. I recorded some wild tracks, 20 segments. Until here, no problem. In the end I put the last recording into play, just for control. The recorder gave me an error and crashed. I turned it off and on. The folder with its contents had disappeared. I opened the card with zaxconverter but does not see any folders. You know how to recover files or I have to give up hope. Thanks in advance.
thanks men Blu Loctite is tasty solution
I'm waiting to digest the Christmas dinner and I got obvious question (maybe I ate heavy). Someone tried to replace the knobs of fusion successfully. I have to tighten periodically to stop them. I think it's a common problem. If these new knobs were also beautiful as those of the sound devices 442, which miovono with a finger I might swallow them as a digestive. thanks and best wishes
thanks to everyone I have already requested the demo version of Soundminer V4, but there isn't a lot to try, I take time before to pay $ 599. see you
I did't find posts on this topic I have accumulated through the years a mass of sounds of all kinds. This material is invaluable when I find the sounds that I try. The sound library on my computer is like a messy basement. I have tried several times to make order. Now I thought, there is this thing called metadata so why not use them to create smart folders, smart playlists, etc. In a few days I came into a world. I realized that I need 2 layers. First, an environment where I can edit the metadata. Second: an environment where I can search by keywords. There are no problems for the first level, there is in fact a wide choice of applications. There are many programs for editing metadata, my favorite is Wave Agent or BWF widget pro. Second level is more complicated. Programs like Audio Finder, Library Monkey Pro, do not go so deep into reading metadata. In this way, the search power is limited. I do't know sound miner, but from what I have read is similar to the others. The key point is that the descriptions are't embedded on files. To understand, Pro Tools does not read any keywords or tags saved in Audio Finder for example .. I hope it's clear my problem. I would like a archive environment and search based on metadata contained in brodcast wave. Someone can help me? thank you.
Hello everyone I read with great interest this post. One thing I've learned over time is that "less is more"! of course, this rule does not apply in any case, but there are exceptions where you need of the dressmaker or hairstylist or of diy accessories. Often add not solve, often shifts the problem and the sound gets worse. On the one hand put tape or felt near the capsule improves the rustle but on the other hand is as if you add a kind of high-pass filter unintentionally.
hello Somebody uses programs like Audio Finder, Soundminer, Library Monkey Pro. I'm looking for the right browser to keep ordered in my sound library. I saw that Audio Finder does not handle metadata very accurately, but you can drag the files directly on the timeline of protools. I would like to be able to manage all my sound archive with a single database. Can anyone recommend me a program?
Hello I'm almost new on this forum, I'm an Italian sound mix. Now that Deva and Fusion are officially discontinued, I hope that Zaxcom not forget to update the firmware. I hope to find under the tree for my fuzion 12: Nverclip AutoMix Support for FP8 Trin indicators in the main display Compressor indicator in the main diplay Did I forget something? Someone has information about it?
now or by the next firmware?
- 4 replies
- Fusion
- control surface
hello I introduce myself, I am Mirko, I'm an Italian production sound mix. I ask you a question, perhaps a heresy, has anyone ever thought of making a control surface for Zaxcom Fusion. My idea is to have 8 friends trim and 8 meters (only three LEDs are enough). A controller like a mix 8 without fader which is small enough to fit easily in the sound bag. Thanks. (forgive my english)
- 4 replies
- Fusion
- control surface
I have read this post now. I recently switched to Fusion and I'm looking for a small keyboard compatible. Jack, maybe you've changed your keyboard, but the one in the photo is what brand name? thanks
