Website URL
http://www.tongaudio.at
Vienna
Sound Mixer for Film and Television
http://www.tongaudio.at -
3,564 profile views
I smell some kind of "racism" here, non US/EU brands is not equal to "low quality / bad image"! To be honest, our industry has been ruled by US and EU companies forever, I would love to see if there could be a chance for a cooperation between companies like Zoom and Aaton, developing more reliable and affordable machines. I think the cooperation between Steinberg and Yamaha is a positive example. The Zoom F8 series are fantastic products at a relative low price. They gave many people the opportunity to get into the world of cinematic sound, those couldn't afford it before such machine existed. But since here is about Aaton, let's give it a hope that Aaton can find an investor and keep making one of the best machines for the industry.
Let's not forget Sonosax, they also make fantastic recorders and mixers, and well-suited for drama/theater use.
I had today some people came to my home to paint the walls, and they were using a kind of exoskeleton system to support their arms when they were painting the ceiling. This made me thinking, if we can use such system for boom operating. There are electric powered systems and non-electric mechanical systems. Has anyone have ever tried such systems or any experience? One of the systems I found is this electric-powered one, it's pretty expensive, but looks interesting.
It's a personal preference thing, all the brands you named, K-Tek, Ambient, VdB, Panamic make solid boom poles, they can all get the job done very well, maybe go to a local store and try them out. Personally, I use VdB because they were the first one who introduced the Quarter-Turn system (I have worked many years with ambient poles before I got my VdB, always had some issues with the locking system). And their Boom Pole is a bit lighter than Ambient, and the VdB has Quick-Lock system built in. As I'm based in Europe, service and replacing parts are easier to get from VdB compared to K-Tek.
I'm not sure if it's the same cause, but with nomad, it needs about one second for the machine to get the timecode after the whole booting up screen is done (apply to both internal and external tc source). If you start rolling right after the machine boots up, it didn't get the timecode yet and will start at 00:00:00:00. This happened to me several times.
Neumann KH120ii (they just announced a new version) is in my option the best for small studios, it’s not overpowered, has a bit of this cinema „horn“ character. I combine them with a Genelec Sub (which allows 5.1 configuration), you can also go for a while Genelec setup. I use Genelec 8020 at home for some very small emergency editing stuff.
Almost, that was a project about the wind "Bora" in Croatia, was physically extremely challenging, (The local people said they measured 235 km/h at that night, the exact spot we were shooting might not be so strong but was still extreme) I felt very fortunate that beside the Pianissimo I had the Cyclone with me, otherwise would not be possible in that situation.
I hope they could make it as a replacement for timecode slate. For example, by pressing a button, the display shows some image for one frame, with a tone signal. That would make it much more useful than just a timecode display bar, in my opinion.
I partially replaced my Pianissimo with Nano Shield, with the Nano Shield I can switch between Sennheiser MKH8060 and MKH8050 by only switching the shield module, that gives me a lot more flexibility compared to the pianissimo. And the Nano Shield is lighter than the Pianissimo. About the handling noise, I just need to adapt my way of booming and know what kind of movements I need to avoid, that's not a big issue. It was the same with Pianissimo MS Setup. Once I was working on a film about wind, the Pianissimo with MKH8060 did not survive under the 230km/h wind situation, but the Cyclone from Rycote with MiniCIMIT did the job. I would say, see what one can improve with the booming technique before blaming the equipment, compared to the old windshield, the Nano Shield is a thousand miles better.
SFX and Foley are mostly recorded in mono, because that's the "point sound source" you are going to move around either in Surround or in Atmos. Ambience should be at least in surround these days in my opinion. I record my ambience in ambisonic. For non-standard experimental sounds, It's very depends on what kind of sounds you are going to record, but the microphone array is always connected to the output format, the standard ORTF or AB or XY etc... are based on the standard stereo 60 degree loudspeaker setup as output format. I'm not really getting the question about phasing issue, if you are going to downmix to mono, then why with array? If in stereo or surround, phasing is normally not a problem. https://www.dpamicrophones.com/mic-university/immersive-sound-object-based-audio-and-microphones This might help you to get some more information about microphone arrays. If you have other choice, avoid MS and Double MS, they are more like a compromise solution for location recording in my opinion.
"The goal is to hear as close as possible to what a human hears in the room" If this is the goal, I would not use any shotgun, they does not simulate how our ear works at all. How we hear has a lot to do with Psychoacoustic (i.e. head related transfer function) and visual informations (which influence a lot of our acoustical focus) I would not use any Shotgun in this case, they will colorise the sound, especially in a church where there's strong reflection from every directions. Try with Omni (or boundary microphones) , with EQ and Delay compensation, mixing together with direct signals, it will get you much closer to the result compare to two shotguns. You can DIY some Boundary microphones with cheap Lavs even under $100/piece. There are also some 3D Models for 3D Printed Binaural Mic, using Lavalier Microphones.
that make sense, any adding electronic parts could cause problem. but in the real world it’s all about compromise, in the best case would be no RF at all but everything cable. I would be interested, things like Zaxcom MicPlexer, SoundDevices SL and Audio Wireless DADM, they are all powered RF distributors, I would not assume that all these Products will ruin the RF with their electronics and the capability of powering active antenna.
I'm using BSRF AS-62 in my bag, with 1 x Zaxcom QRX, 1 x Wisycom 42, 1 x Audio A10, the BSRF AS-62 itself has power supply for active antenna, but you can turn it off, so in this case it's a passive system. the AS-62 has no amplifier build in, but only power supply for active antenna, in this case, it's not an active splitter+amplifier system, but a passive splitter with 470-700MHz Bandpass filter. I think you can even unplug the power for AS-62 and it works as a passive splitter (have tried once and it worked). The Mini-Circuits one has no band-pass filter, which can cause some problems if you are very close to Walki-Transmitter or Mobile-Tower. Like the post above mentioned, I would never use active Antenna or use active amplifier in a bag, also Glenn from Zaxcom mentioned that one should not use active Antenna or amplifier with digital wireless systems.
I was student and later friend of Jecklin, if you ask him which microphone, he would definitely say DPA. DPA 2011/4011 and Sennheiser MKH are better for outdoor use compare to Neumann because they are pre-polarized electret condenser microphone (the Sennheiser even has the HF Circuit) which makes them more resistance to bad weather condition, extreme heat or humidity. But many people say external biased condenser sounds better and has less ground noise, it's a question of personal taste I guess. DPA 2011 or 2006 would be a very good alternative to Sennheiser MKH, with lower price.
switched from Pianissimo to Nano Shield CB about 5 months ago, feel the Nano Shield is lighter than Pianissimo, handling noise about the same (using vdb boom pole), and it's much better switch between indoor/outdoor with the nano shield as you can take off the basket (not possible with pianissimo). Now I use pianissimo only for ms boom, and nano shield for mono boom. The construction and material from nano shield and pianissimo is very similar, from my experience there's not much difference with wind protection.
