Sofia, Bulgaria
Interests
Electronic Music / Movies
A location sound mixer working for american movie projects. http://www.ufofilm.com/
Here is my imdb profile - http://www.imdb.com/name/nm2870347/?ref_=fn_al_nm_1 -
Skype
ataneus1
2,659 profile views
Hello. Thanks so much for this advice. I tried it and works perfect this way. I actually don't even need a splitter now. This was really good idea.
Hello, maybe the question will seem stupid, but let me ask. Can I use the Sennheiser ASA 1 - Antenna Splitter 2x1:4 to combine my Sennheiser G4 SKP500 plug-on receiver with the Lectrosonics Venue Receiver 1 . My goal is to use common antennas for both. What worries me is that on the BNC connectors for Antennas A on ASA 1, 12 volts current flows to power Sennheiser receivers, and if I plug this into the Lektrosonics, could it damage it?
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/ZOOM_F8_compatibleCards.pdf
Try this update - https://us.community.sony.com/s/contentdocument/0694O000007X3wMQAS?language=en_US
Yes I think the same way. Feels the same if I use my Zoom F8. Don't have this problem with Sound Devices 788T
Ok guys. I can't understand your problem. I thought this forum is about talking and sharing not just hating! Both of you have never seen this mixer neither to use it somehow? So just to make some possible judgments is not really cool. I know you don't like it but we are just discussing. For example Yamaha 01V96i is noisy and AC powered but many people in the States use it and like it. Never seen a bad word about it. So why we can try to find some proper alternative= 12volt powered, good pre-amps, enough outputs and small size ? That's the point.
Thanks Jason
Thanks for this review. Nice to hear some feedback about this new unit.
Atanas started following ZoomOfficial
No info about timecode options at all.
Happy birthday Jeff All the best
Just got an e-mail from StudioMaster. They told me the accurate weight of digiLivE 16 Mixer is 5kg (5kg= 11lb) and 10kg (10kg= 22lb) boxed.
To be honest its really strange that we can't find any manuals or full specifications of this mixer. I was attracted by the size and the 12Dc power option. Can't find anywhere info about the weight ? This 20kg info is not possible at all. I think you can get 8 iso outputs from the 8 XLR outputs on the back. Its a question of rooting. Also I really hope that all the inputs can be switched between mic amps. or line level inputs. Don't know also for the digital output options. Probably we should wait for some more info to be available.
Hello Just want to show you something new - Studiomaster digiLivE 16 . Finally a great digital mixer with 16 inputs/ 8 analog outputs (*digital outputs also available) and the most important thing is the power supply - 12 volt DC !!! So no need of any additional power convertors. Also the size is really good. 100mm faders and HD touch Screen. The price is more than good - Didn't see it yet but I plan to check it out. Studiomaster digiLivE 16 https://www.amazon.co.uk/Studiomaster-digiLivE-Digital-Console-Motorised/dp/B01KFZZAV8
Ok its time for my review for Zoom F8. I have it since 1 month and used it in the last documentary show. What can I say. Its really nice and stable. Works perfect and have all the necessary things / settings that we all need both for feature or documentary films. And as all the others I want to share some thoughts about some imperfections and possible future settings updates. First about the pre-amps. They are really high sensitive so using an additional mixer is mandatory. Second its will be good if alphabetic letters like "I" and "O" do not appears in the character's scene increment mode. Third there should be a way to set a take number manually , not just take reset mode.
Atanas changed their profile photo
"Soundcraft Signature 12" - 12 volt DC modification
Atanas replied to Atanas's topic in Technical Reference
The MeON Its actually working . I can use it for the the Sound Devices, Lectro, Comtek and etc. This way uses like 3.0 Amps from the Meon and its ok. Works fine for at least 1 hour without any AC. Its like 10 years old Meon If I plug the mixer's inverter to it then goes like 5-6 Amps and starts producing some mechanical/electrical noise. Can you please help me and tell me a bit more ? What kind of Nickle Metal hydride batteries I need to buy ? I open the MeOn once and I saw its like a pack of some small batteries parallel connected to each other. I was wondering what kind are those batteries so I can order some similar. Thanks
