Jacek Zagaja
  • Content count
    32
About Jacek Zagaja
  • Rank
    Hero Member
    Szczecin
    amateur camera operator
  1. Jacek Zagaja
    Nagra Stories Sound-men won’t ever tell
    How to use this IRT version with Aaton XTR camera and Origin master clock? Can Aaton start/stop Nagra when initialized with TC generator (Origin). If not initialized it camera sends ASCI code (exposed on film) through Lemo 5.
  2. Jacek Zagaja
    Aaton XTR sync start/stop
    Testing Sony walkman with Aaton modd. TC received from Origin - red diode blinks. It doesn't start with wooden grip. Do you know this mic socket? XLR mini?
  3. Jacek Zagaja
    Ok disassembled Tuchel and cable has signal wire plus shell. Do you remember pinout in Nagra? 1 is ground and 2,3 is signal. I should short 1+3?
  4. Jacek Zagaja
    How connect 816T mic to Nagra 4.2? Plug/socket has different diameter, Nagra has modern XLR socket. Mic comes with MZA15 battery adapter and MZF15 highpass filter.
  5. Jacek Zagaja
    Thanks for explanation David. So I'm looking for universal mic pre, plexi cover, rubber gasket. Is there external crystal sync (record and playback) for Nagra SN? Purpose of red cover?
  6. Jacek Zagaja
    And advice how use LN (low noise) vs. STD tape selector. Crystal sync works, QLSI is there.
  7. Jacek Zagaja
    A bit strange T12 cannot be switched off.
  8. Jacek Zagaja
    Yes Google explains opposite connection only.
  9. Jacek Zagaja
    Nagra 4.2 can be started/stopped shorting Mixer pins - will test soon. But my newly purchased 4.2 has T12 only (no selector). How can I connect P48 mic or dynamic?
  10. Jacek Zagaja
    It is key code because I did not have OriginC to initialize TC. I thought I can extract TC from audio file and see in let say Premiere.
  11. Jacek Zagaja
    David, I have no problem requesting to scan whole are of film. See attached scan of Ektachrome 400. ASCII code is K452 from XTR.
  12. Jacek Zagaja
    Constantin, I want point and shot and not bother with sound at all - like a camcorder. First we discussed trigger coupled with camera button but there is no solution we must hack remotes for popular recorders. Second solution is timecode exposed on film and in audio file but I am amateur and don't know how to handle in popular apps that why looking for advices. If I could have time code displayed with audio file then could copy fragment that is on film and combine. Is there any other solution without pushing rec or slate button each scene?
  13. Jacek Zagaja
    Keylink is no go. I asked my lab and response was null. Why I can't do this manually?
  14. Jacek Zagaja
    I'm interested if Aaton code could be read from audio file.
  15. Jacek Zagaja
    This is how TC on film looks like but my XTR prints ASCII only.
