Freeheel
  • Content count
    432
About Freeheel
  • Rank
    Hero Member
  • Birthday 01/01/1
  1. Fingers are crossed. Thanks! Brent Calkin
  2. Hi Karl, Nice to hear about expanded frequency options for a change... Do you know whether these frequencies are viable for use in Canada? Cheers, Brent Calkin
  3. Freeheel
    Rechargeable battery management on location
    yep, the direction of the battery can be done nicely with the AA caddys that look like mini bullet magazines, with negative out for charged and positive out for discharged. I do the same with iPower 9 volts in their sleds, works like a charm. Np1s get a strip of tape sideways across all the contacts when charged, and the same piece of tape stuck vertically over a couple of them when discharged. Cheers, Brent Calkin
  4. Freeheel
    Rain protection sound bag
    Light vertical rain- clear Sealine brand map cover- used for protecting sea charts while kayaking. https://www.mec.ca/en/product/4013-113/Map-Case Similar to the more dirtbag, but effective trick of using a piece of clear shower curtain. Heavy sideways rain- Sachtler poncho is awesome. You don't want to be exerting yourself much in it, cause it doesn't breathe- though it's loose enough that a fair bit of air moves inside it. Cheers, Brent Calkin
  5. Yes, Sound Devices used to have a nice useful little forum as part of their website. As a loyal SD customer, it's a shame I can't access their current forum system. Cheere, Brent Calkin
  6. Freeheel
    Longest lasting
    +1 on SMQV UM400 with Ultralife gets about 10 hrs IIRC Cheers, Brent Calkin
  7. Freeheel
    Schoeps MK41 capsule cleaning
    What did you actually do? Was there lint building up on the diaphragm? Cheers, Brent Calkin
  8. Freeheel
    T power to 48v
    +2! Pete did a pair of 416s for me. Lovely to leave those heavy crackling 48-12T barrels in the "Hope I never have to use these again" bin. Cheers, Brent Calkin
  9. Freeheel
    Next level on-camera microphone in M/S
    The CCM MK4 is a great centre mic for M/S and I'm not surprised you like the sound of it. For the side mic, my understanding of the Emesser is that its fairly noisy, from whats been reported on this forum. I'm not familiar with the Kortwich Acht at all, but it looks like a neat little mic, and would be quite worthwhile if its self noise specifications are good and it sounds nice. I like its capability of going from figure 8 to stereo with a cable changeover. Have any of our usual audio pros played around with the Kortwich Acht, and can give us an opinion on it's sonics and noise floor? Cheers, Brent Calkin
  10. Freeheel
    Soundbag as Hand Luggage
    You should probably check your boom pole to be certain you will keep it. They seem to raise some alarm in security officials. I stopped trying to get mine into my hand baggage years ago after constant hassle about carrying something that could be used as a "bludgeon". Last time I carried one on recently (only because we needed to shoot immediately upon landing in the airport- and I was carrying a spare cheapie) i was given a fair bit of hassle until one of the security people asked if it was a camera monopod- to which I agreed - and this somehow made it OK... But I feel like I got lucky on that one. YMMV Cheers, Brent Calkin
  11. Freeheel
    To answer your battery question. ALL your loose lithium rechargeables need to be carried into the cabin. Some airlines let lithiums that are installed in your gear go into the cargo hold, but I don't generally trust that and remove as many as I can. Especially since your flight can start with one set of rules and change as you go. Japan was the most stringent I have found, with their security wanting ALL batteries carried on, even AA in alkaline and NiMh chemistries...\ Cheers, Brent Calkin
  12. Freeheel
    Sound Devices Mix Pre-3 and Mix Pre-6
    I've had the same experience on my Mixpre 10, and to answer the comment above, it's good to have the option of having EITHER "undecoded M/S" or "decoded XY from M/S" on the ISO's. There are times when both ways are useful. If just doing stereo recordings, its nice to have the ST outs as decoded regular stereo, and have the ISOs undecoded for later processing if required. I find the Mix Pre series has other strange Mid Side issues. Like having the gain trims linked, which would cause problems if you were to use mics with different gain structures and needed to balance them with the trims. I've also talked to SD, so your report should not have been the first. I think the M/S implementation on all the Mixpres needs further work! Cheers, Brent Calkin
  13. Freeheel
    Underwater Mics
    I did not have the opportunity to test the more expensive Ambient mic, (the ASF-1 MKII) and would love to hear some real world opinions on it. The Aquarian I was using was the "plug and play" H2A-XLR. I had it plugged straight into a Sound Devices 744T, so it should have been a pretty ideal signal chain. Their manual notes that high frequency response is reduced by cable length, but I only had a 30ft cable on it, so I doubt if that was the issue. The manual claims a frequency response of 20hz to 100khz, but my experience would indicate, even if that was true, that the response graph would be anything but flat, and I find it irritating that they would leave that detail out of the specifications. Cheers, Brent Calkin
  14. Freeheel
    Underwater Mics
    I used the Aquarian Audio Hydrophones this fall on a shoot and found they sounded pretty good for the price. The main issue I had with them is that their high frequencies are drastically rolled off, so that although the humpback whales sounded OK, the sound of water lapping on the boat was really midrangy and boxy sounding. Unfortunately, we all know what water is supposed to sound like, so I wasn't completely happy with the results. The nice thing about having the high end rolled off though... is that the Aquarian audio mics noise floor is pretty good, and, as well,they have good sensitivity for quieter sounds. I also used the Ambient ASF2 hydrophone. This is the more budget of the two that Ambient sells, and costs about twice what the aquarian audio mic sells for. It has a really distinct hiss, which kind of ruins it's flatter frequency response. It's also quite quite an insensitive mic and really needed a lot of gain, which didn't really help its noise floor either... I also had the opportunity to work with some really expensive ($10,000) hydrophones, which sounded great, but are really just ridiculously priced for casual or occasional use. So I'm still looking for a decently sensitive, low noise floor, flat response hydrophone that doesn't break the bank... I like all these stories of using countryman lavs, and they work in a pinch, but they aren't so great for a job where you want to be slinging your mics into 40 feet of salt water at a moments notice, several times a day... Cheers, Brent Calkin
  15. Freeheel
    633 loose object inside machine
    Yep, that sound would worry me a bit. The machine comes apart pretty easily and also goes back together without issue. I'd dig into it if I were you. Cheers, Brent Calkin
