Website URL
https://contactscott.com
Austin, Texas
Full time freelance location sound mixer based out of Austin, Texas.
2,522 profile views
Two different FX9's two different shoots same issue. Glad for your comment in particular acdave that there were no complaints from post. Set my 633 to bounce one of the channels when sending tone and both input 1 and 2 on the camera were showing correct (iso) VU's and when listening to camera with headphones my tone was clean both channels. It's just the menu saying shoe input on one and can not proceed to change it to input one. Seems to be some bad code that Sonny Boy needs to fix but the physical switches appear to route sound fine even if it doesn't say so.
I am well past my 2nd vaccine vaccination, any questions
Scott Anderson replied to MartinTheMixer's topic in Current
I've got a regular client who said if fully vaccinated then no need for antigen tests with them anyway. That was a plus to me where I've been going for the better part of a year with stress after the swab about what it will be pos or neg as in do I work, or do I go home and miss some real income. Got the Pfizer yesterday first dose, and no side effects other than a somewhat sore arm today. I was working a boom over Robert Rodriguez a few hours ago, and wasn't sore enough to notice. Got antigen tested before work this morning, and was negative even less than a day after the first shot. So far so good where the 95% effective for the next six months Pfizer takes some pressure off the inevitable antigen tests that most productions seem to be doing now days. -
Scott Anderson started following Looking Into Buying Zaxcom IFB , FX9 Sony - No Ch1 - help , I am well past my 2nd vaccine vaccination, any questions and 3 others
Thanks for your thoughts Philip, I do have Dan Dugan's algorithm enabled on each track, and it's been a very helpful tool. (Dugan's automix is amazing.) I have zero experience with NoiseAssist or CEDAR sdnx plugins though, and at $1,100 for four instances, thought I'd ask for input if that investment would help with crosstalk in particular. Good to know that it wouldn't, but from the samples on the Sound Devices site demonstrating how they can help lesson background noise, I can hear how they could be good tools for that use in particular.
Anyone have any experience with Noise Assist on their 833 helping with talent crosstalk? Some times talent talks over each other and although iso'd on individual tracks, their lavs still pick each other up. Room tone of course, but I'm wondering if Noise Assist might help post out with crosstalk.
Sound Devices 633 Internal Battery Dead
Scott Anderson replied to Scott Anderson's topic in Equipment
Very helpful info guys and appreciated. In particular, thanks for the link Dan and model number Josh. Will hope it's not the buffer battery, will see after swapping out the 2032 first. -
It looks like the internal battery on my SD633 isn't holding a charge in that when I power down the unit within seconds the blue LED stops blinking and when powering back up timecode is lost and has to be re-jammed. Anyone change the internal lithium-ion rechargeable battery in a 633 before? I'd rather not send the unit into SD just to replace a battery.
Larry, I've valued your input on this forum for years. You've definitively answered my question about 2.4Ghz being (increasingly) crowded; in particular, your observation that AC powered devices are able to use the full two watts allowed which would inevitably over power the more humble transmitters. Thanks
Helpful info folks and sharing your experience is much appreciated. Getting a more clear idea as to Zaxnet range using 2.4Ghz that a third party booster is most often used. I do mostly bag work so the extra box (and draw on the NP1) may not be ideal for me. It's looking like sticking with assistive listening devices around 216Mhz may be the best set up for what I use over the shoulder. Thanks again for the input.
I've owned and used Lectrosonics R1a receivers in years past and currently own and use Comtek PR-216 receivers, but its time for a change in that the Comteks just aren't performing as reliably as needed. The signal needs to be consistently clean and clear as the client's opinion of my work is influenced by what they hear over IFB. R1a receivers are rock solid and sound fine, but I want to get away from using 9v with a battery life of 8 hours per alkaline. The several days a Comtek will go between battery changes is exceptional, but the 10mw M-216 Option P7 transmitter and plastic case on the receivers have been weak points. So I'm considering Zaxcom for IFB because it's the other option I don’t have experience with, and maybe I've been missing out all this time? What's your experience with an IFB200 to ERX3TCD? In particular, is the range reliably up to 100’ with Zaxnet using 2.4Ghz? Seems like there are so many devices using 2.4Ghz with everyone having a smart phone etc etc that interference could be an issue.
I have with my iPhone 7 plus and the lightning to 3.5 works well
We do a bunch of windshield time in Texas with several hours drive between the big cities so something that cruses an interstate at 75 but still gets decent gas mileage is a consideration. I'll also get asked by a producer to jump in my car (billing mileage) so something that represents my business well with a client is important. I've worked Weather Channel storm coverage too many times over the years so an all wheel drive with good ground clearance has gotten me through flooding, blizzards, and hurricanes many times. One last consideration is the most important and that's does the gear fit in the back without too much hassle pulling something out of the way to get to something else underneath. I'm on my second Toyota RAV4 having sold the first only because it got to be so high of mileage I wanted to make sure and have reliable transportation. So I found a low mileage used 2012 to buy. Only thing is, Toyota changed the body style and the engine option with the 2013 year model. The 2012 has a V6 that I get 28MPG and the spare tire at the back allows for a bunch of stuff to be stowed below the deck. A RAV4 2012 with V6 AWD has been great, but after this one gets higher miles I'll have to look at other makes and models as 2013 and later years don't have the features that work for me. A dodge Caravan with Stow-n-go seats is commonly rented by production as they hold an amazing number of Pelican cases and/or people which makes it worth considering as a production vehicle. Similarly, a Ford Transit Connect wagon (the smaller one and not necessarily the full size van) has some production friendly features that makes it worth considering. A vehicle is a tool for our trade with location sound work where I tend to lean toward looking at makes and models that are more practical.
Having more than one make / model of lav mic in your kit helps. Most of my lavs are COS-11d's which certainly is the go-to, but a Countryman B6 can be a real problem solver. It's small enough to just barely poke out from under a tie knot, or a shirt button hole, or top stick taped over the top of an ear or even above the forehead in the hair if there's enough time to rig it. B6 w/o a windscreen is crazy wind (breath even) sensitive so using them indoors when taking advantage of their dimenuitive size by hiding them is helpful.
Working regularly on a cable reality show where the DP rents a Bolt. It's wreaked havoc on my Lectro block 19 SRb receiver creating a scenario where a wireless hop from my bag is useless. Bottom line in my experience with a Bolt is it's either wireless video or wireless audio from / to the camera but not both at the same time. Agree also with prior posts (even a couple years later) that cheap BNC cables that lack good shielding can spew out a crazy amount of RF also creating havoc for a wireless receiver. Most of the shooters I work with like having a color monitor up on top of their camera for reference but they also like spending as little as possible (so it seems) on BNC cables which is a lousy combination for RF hit free sound on the wireless hop.
Enjoyed reading that thanks for the link.
Zaxcom TRX900CL in an adjacent block to an SRb in a bag
Really helpful input Matt, Glenn, and Whitney. Thanks!
