Hamburg Germany
Doing sound on set since 2001
6,737 profile views
Vac cleaners use high power slip rings and are kind of crude for a mic signal and difficult to isolate from EMI. Their systems are quite big, for longer and thicker cables. Some even only have 2 "channels". The better ones come with constant torque springs rather than power springs. Over all, they are not made to be taken apart and I have given up attempts to harvest them from old units before. A DYH-1703 may have the right dimension, though also not small and the breaking system would probably need some modification to be quite. I do not have or have used one. I do use a DYH-1816 without the break on the boom but 3m max is probably too less for a bag to boom scenario.
Where is the boom resting on? Or what?
What is going on in the first photo? Found on Ambients website
Is that actually an issue in the 1.8m-2.7m range with e.g. a Piani as mentioned? I hardly have the need of such a pole outdoors. I see the disadvantage over more sections in pre operation handling and in overall weight (and rather slight, when fully expanded) balance advantage vs transport and occasional horizontal storage on a sound bag.
Great work! Thank you for sharing.
I suppose, this would have an influence on the 788t used market. Though I do not operate a 788t, but did many years, I would prefer to see a cabled android device, RaspberryPi with touchscreen or similar.
Bavaria is not in France.
The DYH re-tractor is far from ideal. It has a power spring, but a constant force/torque spring would be far more feasible. Also, it comes with a locking mechanism that is useless and leaves behind some dead air in the enclosure. The whole thing is not very service friendly and for the full 3m expansion slightly smaller than one would wish. I have not found a material / construction platform to develop something optimised for our needs from scratch. In the end, it would most likely be some router/mill processed aluminum alloy, like camera cages or cheeseplates. But prototyping with it is very expensive and resins as tough as they are advertised have viscose properties under permanent tension. I might end up with plywood or end up working with what is there. The last image shows the smallest of the "washers" in the upper segment of the Quickpole.
I use a modded DYH-1816 cable retractor populated with Mogami 3031. That just about fits the max 3m for an Ambient Quickpole 5100. It is attached to the 5100 by an 3d resin printed clamping holder. The latest version of the holder also accomodates 10oz worth of tungsten weights from the archery industry as Hodges weight. The lower ends of the booms pipes are fitted with "washers" that guide the cable and prevent it from flapping around during operation. In the latest Version the "washers" do not have to be glued any more. I do mainly wireless booming on fictional shows with it, but also use it on 1 man show style bag jobs. As a DIY solution it helps me a lot, but it is far from a commercial product. I'd really like to make a more custom system that allows for more cable/boom length.
I have a 4minX. I hardly use it, but good to have. At some point I will sell or barter it inside EU, so, I am not advertising mine to you. I cannot confirm the slight tone at (was it 8?)kHz. Maybe my unit is not affected or I just don't hear it. It can be notched out later anyway. 2. The menu and overall firmware design did not reach adulthood and things like metadata, monitoring matrix, menu ergonomics and some other foo are a complete pain in film workflows. Probably much less so in music room recording, if you can prepare in advance. It has 4 analog inputs, yes, all with 48V, but they come in two pairs with diffent dynamic ranges! Dig the specs, and compare with other brands/models mentioned in this thread. You can add more channels with an old MixPreD or Sonosax M2D2 via 2 AES pairs that also offer AES42/SRC btw. The unit is quite big, but it is still light as they enclosed a lot of air. The main reason why you probably won't buy a 4minX is, there is virtually no market! At least last time, I checked.
Did you consult https://www.lectrosonics.com/phocadownload/SMWB_man.pdf Page 17, line level signals?
Ask your dealer oder try it out with ENC/ENR. All I can tell you is, it worked and sounded good.
I've worked with EK 300 receiving the signal from an MTP40 (in proper compander mode). Subjectively this had less noise floor than the variouse SK units and being able to tweak the transmission power improoves range slightly, e.g. compared to an SK100. The price is obviously much higher, but if you have a spare Wisy TX around anyway, it is an improovement.
Videndum (aka Vitec) cybersquats on Radius Windshields name?
DanieldH replied to Jim Feeley's topic in Current
Is it? For now, the Nano is advertised on rycote.com and listed on common dealers sites. (not doubting this info, just curious for the source)
