Emory Murchison
  • Content count
    48
About Emory Murchison
  • Rank
    Hero Member
    Montreal
    Soundie too old for this shit.
772 profile views
  1. MixPre 10t output level
    No I guess not. They are protecting the 6 series I suppose. Sent from my F5121 using Tapatalk
  2. MixPre 10t output level
    Sony f5. But I tried also feeding tone into my 302 set to line and I also had to almost max out the gain to get 0dBu. After a few experiments I figured out that the x1x2 output is an exact level match for the tape out/mix in on the 302. From the specs I'm guessing the main LR out has the same level. I was really hoping to fall in love with this unit but sofar not so much. Also no level meter when adjusting gain! Yikes. Sent from my F5121 using Tapatalk
  3. MixPre 10t output level
    Has anybody figured out the reference output level of the new MixPre series mixers? It says max output is +7.8dBu, but does that correspond to 0DBFS? Hooking up line level to a camera doesn't seem to work because the level is quite low. How are you folks doing it? Emory Sent from my F5121 using Tapatalk
  4. Radio mics in Moscow
    Anybody have experience working in Moscow? good/bad blocks, general advice. thanks! emory
  5. Zoom F8
    I've been using this on a few documentary projects. It works great! I had a few noise and RF interference issues at the beginning but I sorted that with some carefull bag planning. This is not a mixer. Switching back and forth between trim fader and pan using the same knob that is not an endless encoder just doesn't work. Also no camera return. If you need mixing capability get something else. I haven't tried the app yet. Noise floor hasn't been an issue but the preamps are more hissy than what I'm used to. It might not be as intuitive a machine to use as other pro recorders but it gets the job done, sounds good and it's tiny! Definetly makes me think twice about pulling out the Nagra VI if I know I'm going to be on my feet all day... I've used it enough to feel confident that it can perform in a professional context. If I were starting out right now I might just buy two of these!
  6. cycling to work
    here is my latest bike to work setup. my favourite new part is the rifle case for my booms. my bike is a little difficult to steer with the heavy pelican on the back but it works. also note this kit is indoor only. no zeppelins... happy trails!
  7. The quitest ambisonic microphone
    not sure what you mean by "the DPA which i made". can you elaborate? -emory
  8. Can 5DMarkIII handle ERX2TCD
    +1 this works. just be careful with connectors! tape is good, i also used rubber bands!! -emory
  9. Transporting blimps
    i keep my blimp and 4017 with other fragiles in a Pelican 1510 which i bring on the plane when travelling. still mint!
  10. Advice for capturing audio in room filled with poker players
    Just bluff. -emory
  11. just to throw another workflow into the mix: multiple 5Dmkii and Sony FS700. Each camera has a Zaxcom ERXTCD feeding ltc timecode onto one of the audio channels. plop all the audio from my recorder and the footage into Avid sync from the ltc of the video footage, and voila! theoretically it is even possible to also send a scratch audio track, but in practice the level mismatch doesn't work on the DSLR camera's so more gear would be involved or a special cable with one channel padded... also in our situation with the FS700 it was better to have an onboard shotgun. i know this is kind of a special workflow and not for everybody but i'll just put it out there because maybe it will be perfect for somebody else! -emory
  12. XLO Sensitivity Lavs/Mics
    I guess I should be clear that I was comparing a regular Cos-11 with the B6W5 version. The highest SPL listed on the low sensitivity B6 is higher, but in my experience the cos-11 did better even with regular sensitivity. I'm just saying that getting a low sensitivity mic and a high SPL mic are not necessarily the same thing. Ideally you should test for best results in a particular situation.
  13. XLO Sensitivity Lavs/Mics
    my experience with low sensitivity Countryman B6 mics is they didn't help for high SPL situations, even though their sensitivity is lower. So maybe they work best for preventing the mic from overloading the input of the transmitter, but not necessarily for dealing with high SPL. -emory
  14. zax tx with countryman b6 users
    i've used this combination. didn't notice any excessive noise, but it was used in loud environments and pretty close to the mouth, hence the "red band" i did notice that it had reduced sensitivity as advertised, but it would also overload which kind of defeats the purpose. in the same situation using a regular cos-11 i got better results just using lower gain settings. looking at the specs the "red band" version has max SPL of 130dB, and a cos-11 says 123dB@1%THD. I definetly noticed more clipping on the B6. for the noise the difference in "Equivalent Acoustic Noise" countryman says: 24 vs 29 dBSPL, neither of which she be a problem in most situations. to sum up a rambling and off topic reply: noise wasn't a problem for me with the B6W5 and zaxcom TRX900LA -emory
  15. Thom Shafer on boom vs lav
    i know you weren't trying to put down the other guys but this is more than just the difference between lav and boom. lav placement, clothing noise and pretty incredible mangling somewhere in there by some nasty compressor. depending on the placement i am sure there are examples out there where the differences are much more subtle. i also prefer the sound of a boom mic, but i do run into the occasional director who insists on a lav just because they like that really dry closed sound. no accounting for taste i guess! -emory
