Mungo
  • Content count
    259
About Mungo
  • Rank
    Hero Member
    Germany
    ENG, EFP, Sound mixing post
2,630 profile views
  1. I have heard of system crashes on the 664 and the 633 where only a firmware "update" (installation of the current firmware once again) brought the machine back to normal behaviour. So it may be useful to have the file in the kit.
  2. Mungo
    Deity Microphones going Wireless
    - power supply by AA, USB and Hirose, nothing exotic - phase stable stereo over two links - transmitter's battery life in minutes on receiver's display - true diversity - wideband
  3. Mungo
    Mixer/recorder - changing the stereo width
    Hi! You can use the trim knob of the 2nd MS linked channel for that on Sound Devices 633/664/688.
  4. Mungo
    633 track names into Premiere Pro
    Thank you, I didn't know that. Very hard to find though. Picture of Metadata: Sorry that Premiere is set to German.
  5. Mungo
    AETA Audio Systems stops the production of 4MINX
    Had the possibility to test a 4Minx about 5 years ago. It has great preamps and nice options, but 20-40 seconds powering up was too long for my bag work. SD did already better at that time.
  6. Mungo
    Sennheiser 6042
    Congratulations! Does the AES connection work on your 664? I couldn't figure out yet why it works perfectly on the 633 but not on the 664. Well, not a major problem since I go all analogue into the 664, to avoid latency related trouble.
  7. Mungo
    Things I found Helpful
    Thank you for sharing!
  8. Mungo
    Frequencies in Italy / Lago di Garda
    fmscan.org worked well for me. Italy seems one of the countries for which it's reliable.
  9. Mungo
    microphones near gunshot
    Perhaps there's the opportunity to record a simple dynamic microphone onto a separate track? And there's the need to properly adjust (or even disable) the limiters to avoid heavy pumping after the gunshots.
  10. Mungo
    Sennheiser 6042
    Used the 6042 with 20 year old SK50 too and those transmitters sounded better than ever before. There is no preset for them, but the "5200-II" setting did well. So that's probably a good idea.
  11. Mungo
    664 Power Issue
    Maybe voltage broke down a little bit once in a while due to a battery issue? The 664 might have recognized this as a weak battery and have cycled down. Perhaps changing the battery type setting will help?
  12. Mungo
    Sennheiser 6042
    Great receiver, I've been using it for about eight months now, mainly with SK5212. And never had issues. It has an excellent range and great filters (I have a hop transmitter in my bag and there are no effects on the EK6042). Very rugged and reliable, best sound. Much less compander artifacts than with the older EKs. The option to receive EW is great too. cons: the slot adapter is too bulky and heavy and the analogue outputs' level is a little too low if you have to use a line input (SD633 Inputs 4-6).
  13. Mungo
    NAB 2018 Products update
    Here in Germany there's 99% V-Lock usage, in film business as well as in ENG/EFP business. So that makes kind of sense for a company based in Munich. But I too think that no cam op would be happy if you show up with such a brickstone, especially if he or she has used Nano Lockits or Tentacles before.
  14. Mungo
    Maybe stolen gear on ebay
    Fraud
  15. Mungo
    Strange. This auction has ended for 1.250 € which is quite low for this combo. Just one of the Schoeps is worth more than that, even used. But no doubt this is an original Sound Devices cardboard box.
