Shastapete
  • Content count
    304
1 Follower
About Shastapete
  • Rank
    Peter K Morrison
  • Website URL
    http://pkm.cc
    NYC
    Mix and stuff
3,190 profile views
  1. Shastapete
    Rechargeable battery management on location
    That Pelican 1060 with battery caddies is slick.
  2. Shastapete
    Boompole end exit to side exit conversion?
    2 of these connected together? https://www.amazon.com/LyxPro-positioned-different-interfere-applications/dp/B073X2SDMJ But what you probably should look for is a shorty XLR with a right angle on one end and some sort of wrap (K-tek squid?) or something to secure the TX to the pole
  3. Shastapete
    Alvin's cables, has anyone used them?
    I have 2 of the lemo 3pin push/pull connectors and bought a 10 pack of the hirose connectors. I used the lemos to make a mic level input cables for my Zax TXs. So far they've held up great, haven't tortured them too much, but for the occasional times you need to record a board feed (and monitor) while running around they've been perfect. The hiroses have been keeping my bag powered for a while now. No issues there, but things don't get moved around too much in there to cause mechanical stress. Can't speak on their cable construction, as I've DIYed my own, but so far so good.
  4. Shastapete
    Ursa Pro Mini AES not working
    Like most BMD products, URSA was designed in vacuum without regard to how the real world works. Should it have src on its inputs? Yes. But also should Zaxcom be able to put out an industry standard 48kHz (as well as normal 23.98 LTC)? Yes.
  5. Shastapete
    Remoting Nomads Zaxnet Antenna
    This has been sitting in my ebay cart for awhile, https://www.ebay.com/itm/263022626523 I mostly do corporate interviews, so my rubber ducky antenna has worked fine for the past year as I'm at most 10 feet from talent.
  6. Shastapete
    Soundbag as Hand Luggage
    I fly with my sound bag as my personal item, a carry on pelican as my "carry on," and if needed a larger pelican with more gear checked. I have a VdB small pole that fits easily in the carry on case, and if needed I can usually get the camera department to pack a longer pole in their tripod case. You need to be careful though, as your flight could be too full to accommodate your carry on, so you'll need to be ready to pull your batteries out and hand carry them on the plane. So because of this it is often worth it to buy the early boarding upgrade. Check with the airlines your are flying for both their rules as well as the destination countries rules. US rules limit you to 100 wH batteries as carry ons, with larger batteries if approved by the airline and pilot (they won't be)
  7. Shastapete
    Custom low profile right angle plugs - Seen this?
    for $10 a connector it certainly wins the cost vs. labor debate. The current $20 connectors were too much in my opinion. I've heard rumors that new mini connectors were coming from Cable Techniques, and now that they are here I'll be getting a couple to replace the "good enough" DIY monstrosities in my kit.
  8. Shastapete
    Folding Bag Cart v1.0
    Not the same, but similar versions Baby pin version: http://www.filmtools.com/carts-and-dollies/cart-accessories/magliner-5-8-side-baby-pin-mag-np-sd.html Dual side mast mount: http://www.filmtools.com/carts-and-dollies/cart-accessories/magliner-antenna-base-for-vert-cart.html
  9. Shastapete
    Zaxcom TRXLA-series Protective Case
    Any progress update on this?
  10. 2.4ghz is a frequency not a protocol. Wifi, Bluetooth, Zaxnet, and hundreds of other communications protocols operate within that spectrum
  11. The IFB200 can control parameters of the receivers through the menu system on the IFB200, it can also transmit commands sent from a Zaxcom recorder by sending additional data over the LTC timecode stream. If you went with a QRX235 with the IFB board (or QRX100 with IFB) there is a bluetooth dongle and ZaxMote iOS software... but after the initial release it has all but been forgotten.
  12. Shastapete
    BDS connectors
    The Tensility connectors are too short, they'll fit, but they'll have a lot of play as the shank needs to be 12mm long, not 7.5
  13. Shastapete
    Roland R88 b and h today only
    It is now marked Discontinued, must have been a firesale to clear old stock
  14. Shastapete
    BDS connectors
    I'm in the middle of a bag rebuild/rewire. You can get molded right angle BDS (and Zaxcom QRX) connectors with attached power cable. They are part number CARA761KS07984 from Switchcraft. They are $17 each, which stings when the regular connector is just $3.50, but I've been in a buy once cry once mood lately and I'd rather pay the premium to have exactly what I want in my bag
  15. Shastapete
    Recording 160dB?
