Website URL
https://setsound.pro
NYC
Mix and stuff
6,488 profile views
Shastapete started following I have CEDAR Trinity software for a two week trial , Proper cable for LCR setup? , Boom pole for carry on and 7 others
LCR is a spaced array of mics, so I'd probably just do home runs to the recorder. But, you can run 4 channels of audio over a cat5 cable, so since you're not "running and gunning" with this set up, a small stage box at the "C" mic with all three cabled in would give you a small and easy to replace cable back to your recorder wherever you want to be with that – there are many commercial options out there, but it is also pretty easy to DIY
VdB Small is the best short pole (in my opinion) It fits perfectly in a carry on sized pelican. I've flown all over the states with it – easy to change XLRs in the field, I go between mono, stereo, and no cable regularly
I run a DPA4017 and an ATE308 in an MS rig for a lot of my documentary work. It allows me to grab stereo ambience quickly during B-Roll as well as camera perspective stereo in wider shots. I just did a couple days on a choir doc, and they would frequently start singing in random places. So it was amazing to just flip to stereo, stick my mic in the air and grab a decent sounding stereo recording. Not how I'd mic a choir in more controlled environment, but it really adds to the immersion in those scenes
Cat5 and baluns are cheaper than good Coax and much less complicated than Dante transmitters and receivers.
Owning equipment is a business decision. When purchasing gear, the 2 main questions I ask myself are: 1. Does this make me a better mixer or eliminate a stress point in my workflow? 2. Will this piece of equipment get paid off in a reasonable period of time and then continue to give me income (cash-on-cash return) If I can't make a justifiable excuse for either (hopefully both) criteria, then I'll just rent the gear I need.
Looking for Feedback on Myna Universal Fit IEM's
Shastapete replied to dgirtsman's topic in Equipment
Same – I personally hate the sound of the 7506s because of how bright they are. I also hate the sound of genelecs... but I have a pair on my desk because I know them inside and out, so I totally understand why Glen went with the sony's first because so many people use them and know them, despite their flaws. -
When these things first launched, Glen said an HD-25 version was in the works (my cans as well) so hopefully that'll show up and it matches as good as these things -
They sound basically identical, with the CMIT a tiny bit smoother when very off axis. When comparing the mics it is literally a photo finish. (I own several DPA mics, I did not think the minuscule amount of improvement is worth the added weight or $$$)
There's certainly a cost/benefit ratio of not needing to supply comtek/IFBs – If the transmitter is reasonably priced, and "professional" enough, I could see myself getting one and charging to deploy it on set for the agency folks to all connect. Since I don't need to worry about supplying additional headsets or tracking them down at wrap that could save me a lot of grief on set (even though the IFBs basically just print money for me, since clients want them and they're already paid off) What I don't want (and what I'm sure it would turn into) is being tech support for everyone having issues connecting their phone/headphones/whatever to the transmitter. My gear is already pre-configured and when I hand it to them, I know it's already set up and ready. So for the $50/per they're also getting my time, effort, and knowledge for setting them up with something I stand behind.
Shastapete replied to Ty Ford's topic in General Discussion
Cedar's trinity line is aimed at their forensics/surveillance market is it not? I assume it all runs the same algorithms under the hood but this just looks like their existing DNS software with less granular control -
Their website hasn't been updated in a while, but they have this: https://www.gothamsound.com/product/bt100-quad-battery-charger
2 batteries for non-stop recording... or with two types of batteries
Shastapete replied to Boomboom's topic in Equipment
Electricity will flow from the battery with the highest voltage, so when you plugin in a fresh battery (regardless of chemistry) assuming it is at a higher voltage, it'll take the load. If the 2 batteries connected have the same voltage, they will share the load (batteries in parallel have the same voltage but will combine current - amps) and draw down together. The only caveat to all of this, if you have a full battery and a dead battery in parallel the dead battery will charge off of the full battery, so be quick on your battery changes, as this could cause a huge current draw and pop fuses in your fresh battery, so test it before trying in the field. Systems properly designed for multiple battery connections will have diodes to keep the power from feeding into the batteries with the lower state of charge. -
As far as Zaxcom has claimed, it's the same box with added AES I/O – a few different chips inside, but otherwise identical
Again... not likely, because the ZMT-4 (and probably future models of that pack) offer phantom power... it would be a huge step backwards to drop that feature
