cameronlenart
    Auckland
    Sound recordist/Boom op
1,618 profile views
  1. I am wanting to set up walkie integration with my Nova but am getting a bit confused... As I see it there are two options: 1.) I can buy mic that attaches to my HP and plugs into the 'mic' 3.5mm on the Nova then route this to output 6 to the walkie and have a return from the walkie into return1/2 of the Nova. Pressing the com button should open the walkie. 2.) Glenn mentioned that he has successfully used a URX100 lanyard to the Nova. He said the PTT button on the lanyard was functional. He also said the lanyard needs to be connected to output 6 and return 1/2 for 2 way communication. Does this mean the lanyard TRRS connector can be split into mic and HP then plugged into the 3.5mm mic connector and routed to output 6 the same as I would do with the external mic? And the PTT button on the lanyard would be functional?
  2. Thanks for sharing. Have you come across any suitable amps that are a smaller alternative to the L com?
  3. I just ordered this to try out...can post here once it arrives:) https://hobbyking.com/en_us/2-4ghz-2-watt-signal-amplifier-for-dji-phantom-1-2-white.html?___store=en_us Sent from my SM-G935F using Tapatalk
  4. I couldn't find it on SGS or ProSounds websites. Do you know where I can purchase it? Sent from my SM-G935F using Tapatalk DFI Sent from my SM-G935F using Tapatalk
  5. Thanks Nate, nice work for bra straps. Would be good if there were a slide on clip to purchase. Maybe I'll try some 3d printing? Sent from my SM-G935F using Tapatalk
  6. Just got a ZMT, is anyone making accessories yet? A belt/bra clip would be nice:)
  7. I was replying to this sentence in particular. It seems what you're after already exists (ZFR). Zaxcom uses 3 pin lemo connectors not ta3.
  8. ta5-lemo adapter cable like the one lectro is about to release for the SSM?
  9. Are we able to control trim and or faders from the Nomad touch? Ie is this the start of the sound backpack with control surface at the front?
  10. Also it's cheaper if you are upgrading from a previous version of RX. Log in to your Izotope account and check the 'upgrade coupons' tab:)
  11. PSA: RX4 and RX4 Advanced currently on sale. I just upgraded to advanced:)
