Website URL
http://www.siaudio.ca
Montreal, Canada
Post guy thats interested in location sound :p
2,417 profile views
franky03 started following Mixer needed in Philadelphia , New work Paradigm? and Nagra III Parts List
Does your Windows computer installation support usb-c? The usb-c to usb-a adapter doesnt change the protocol of the mixpre (usb-c). Maybe you just need to install a driver... Franky
Ok thanks guys! Franky
Battery was brand new and worked fine in all other tx... Franky
Hello hive mind, I was renting an original Lectro Lm TX from a friend and ran into this problem: it booted fine (lights etc) but immediatly shutdown afterwards. I didnt have much time to look into it so I just grabbed another set of his but wanted to know the cause. Im guessing its in some kind of mode/reset state?!? TIA Franky 1633392735_Lmshutdown.MOV
Can someone please help me fix some bad audio
franky03 replied to Michael Miramontes's topic in The Post Place
Hello! If its not too late I can take a listen Please send it here: francois@siaudio.ca -
Sound Devices 664 not powering up from external DC
franky03 replied to Sebastian Kleinloh's topic in Equipment
Was your 664 feeding the camera too? IIRC if you send phantom power to the xlr outputs you fry stuff... -
All very good advice here! I could maybe add this: keep all the processing real-time as much as possible instead of audiosuite renders. Much easier to change and adapt a setting then to go back to editing in Izotope rx for example. Also, once you chewed and digested your reading, I recommend this podcast: https://tonebenderspodcast.com/097-gary-bourgeois/ My 0.02$ Franky
sync workflow in protools after avid/premier edit with cam audio
franky03 replied to osa's topic in The Post Place
Hey Ken, Ediload is one option: https://www.soundsinsync.com/products/ediload Franky- 1 reply
- 1
Hello all! Im posting for a friend of mine, fully trustworthy: Eric Ruel <I'm looking to hire a professional, and happy, location soundman/woman in Vermont the 2nd, 3rd and 4th of November 2019. We are a small documentary crew. Contact by Email only pdlr_eric@hotmail.com Equipment needed : two lavalier wireless microphones, boom and shotgun, audio mixer (wireless with a Sony F55 camera)> You need to be local for this job. Please dont reply here. Contact him directly. Best of luck! Franky
Hello, I like Unveil and Unfilter. As Philip, I think the user interface is not very straightforward. I didnt know about Acon's offering, will check it out. Unveil: I tweak mostly Focus, Refract and Adaptation. Focus and Refract will control how much overall reverb you remove. Adaptation needs to match the lenght of the reverb you are trying to remove. That's where the GUI sucks as there is no clue on how long or short we can go (Im guessing the starting point is around 0.6s decay time). Tendency to sound a bit thin. Unfilter: Easy and fast to use plug-in when you have unnatural sounding clips. Tendency to sound edgy and slightly harsh. On dialog it will try to bring the bass back, you have to filter the low end. I like them both. They are pricey! My 0.02$ Franky
I agree! It should definitely be a Protools feature, so vote for it here: https://protools.ideascale.com/a/dtd/Auto-sync-clips-using-audio-not-meta-data/79429-3779#idea-tab-comments I think "phrasefind" should also be part of Protools, vote for it here: https://protools.ideascale.com/a/dtd/Add-PhraseFind-option-for-Pro-Tools!/30225-3779#idea-tab-comments My 0.02$ Franky
Hello Lin, I know your pain! It is quite difficult these days to have a "shitbox" listen. Depending on the length of the content I mix I sometime compress a quicktime to play on my phone. Sometimes I put my main monitors thru SpeakerPhone. It can emulate all kind of tv sets and radio sets. I think auratones are way too expensive! My 0.02$ Franky
And if you could come back after and tell us the tricks that would be nice
Hello! Im posting this for a friend producer, she is nice and straightforward: Sound Mixer needed for two days (with mixer/recorder, 2 wireless and a boom) for a docu type shoot at the Curtis Music Conservatory. The dates are yet to be defined but should be between September 21st and October 15th. Please send your resumes, setup and rates to: kanifproductions AT gmail DOT com Happy mixing Franky03
Nice and... crippled (timecode) :-/ Franky
