Refine
    California
    Depends upon what hat I am wearing.
1,010 profile views
  1. I haven't tested the low-sensitivity DPA 4061 or 6061 with the ZMT4 yet, but I have noticed a couple of the lavs I've tested seem to have a little more noise at 5 volts on the ZMT4 versus using them on a ZMT3. Most of the daily driver lav brands/models that I use sound great with the ZMT4. I wonder if it would be possible for a ZMT4 firmware update to include a 3 or 3.3 volt option for mic power, instead of just the 5 volt minimum option. Perhaps Glenn or Howy can let us know if this is even possible given the current hardware/firmware design of the ZMT4.
  2. Yes, adjusted the max volume to 23; still coming in a little low for some cans. When using the ERX2TCD for scratch track/TC, I set MAX VOLUME to 23 & FIXED MAX GAIN. On the camera, I usually SET LINE LEVEL input, MANUAL, and set to 9/10.
  3. Great diagram Justin. By chance, have you found a diagram for the variation of Tx Neverclip?
  4. Any feedback yet on models/types of antennas working well with the Micplexer 2 in bag?
  5. In addition to the low line level issues, I also find the ERX2TCD output to be a little low to adequately drive some of the larger cans that some producers are fond of. Any whispers of an ERX3 with improved output levels coming soon?
  6. So does this work through the QRX235 IFB Option, or is a separate dongle needed? Are users beta testing the Zaxmote app yet?
  7. Many of the drone batteries used today don't have a plastic container/housing, and consist of the cells wrapped in a thin film and then folded/glued, to reduce size/weight. The attached wiring usually terminates in several small molex type connectors that can easily shear off in handling/transport resulting in the battery terminals shorting. Fortunately most gold mount and IDX type batteries have much sturdier packaging and battery terminals. frail drone battery examples:
