Saif and Sound Posted January 29, 2012 Report Share Posted January 29, 2012 Just was wondering if anyone has any experience with soldering different connectors on the Sanken CUB-01. Im thinking of just buying it without any connectors and putting my own 3pin XLR-M. Is there anything in particular to look out for soldering wise? Or is it just straight forward 1 to 1, 2 to 2, and 3 to 3? As far as XLR is concerned. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted January 29, 2012 Report Share Posted January 29, 2012 As long as you know which wires go where you'll be fine but what would you be saving by doing it yourself, $3.00 for an XLR-M? Eric Quote Link to comment Share on other sites More sharing options...
Saif and Sound Posted January 29, 2012 Author Report Share Posted January 29, 2012 Well I was looking on B&H and it's 322.15 for the unterminated version with just the leads. If you buy it with the XLR already on it, it's 489.00. That's like $167.00 difference over a 3.00 connector. That's why i was wondering if there was any special wiring involved or if it was just typical XLR wiring. If so, than i can totally do it myself. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted January 29, 2012 Report Share Posted January 29, 2012 The CUB works like a lav. Simply connecting it to an XLR and sending Phantom to it will probably(?) blow it up. The XLR connection installed at the factory (it's pretty sizeable) converts the 48V to something (most likely 5V) the mic can use. This is why the CUB can be used with wireless transmitters as well... Taken from the Lectro Website: The Sanken CUB-01 boundary mic does not seem to have the usual FET output stage and also seems to have a large capacitor across the power supply lead (bias lead). This means that it can't be wired as the usual three wire microphone with the SM. The wiring below seems to work well and is fully compatible with our other transmitters. Our pin 1 to Sanken shield (ground). Our pin 2 to Sanken black wire (5 Volt power). Our pin 3 to a 511 Ohm resistor and the other end to Sanken white wire (audio). This matches well to our 300 Ohm input input while providing a satisfactory 811 Ohms to the Sanken mic. Our pins 4 and 5 no connections. Quote Link to comment Share on other sites More sharing options...
matt.kraus Posted January 29, 2012 Report Share Posted January 29, 2012 The CUB-01-PT has different specifications and power requirements than the CUB-01 factory wired XLR3M. See: http://www.sekd.com/...nken/CUB-01.pdf Quote Link to comment Share on other sites More sharing options...
studiomprd Posted February 2, 2012 Report Share Posted February 2, 2012 that price difference is for a P-48 to bias power converter, incl impedence matching Quote Link to comment Share on other sites More sharing options...
Max Futterman Posted March 25, 2012 Report Share Posted March 25, 2012 I've had mine wired for Lecrosonics and just used an ambient adaptor for when I hardwired it into my mixer. About the same price give or take a couple bucks and I have a system that will work on both connections. I also tried the less expensive PSC adaptor, but that didn't work at all. Quote Link to comment Share on other sites More sharing options...
Diego Casares Posted March 12, 2015 Report Share Posted March 12, 2015 Anyone knows the CUB's wiring scheme for the Wisycom MTP40? Quote Link to comment Share on other sites More sharing options...
Gary V Posted March 12, 2015 Report Share Posted March 12, 2015 The Wisycom MTP40 transmitter has the capability to power a phantom powered microphone via the PHA48 adapter. This is used along with a CAL48 (3-pin lemo to TA5-F) cable. In the transmitter menu, you would set the lav mic preset to "Phantom" and adjust your gain level. Look under the accessories tab on the webpage. http://www.wisycom.com/www3/products/category/bodypack_transmitters Quote Link to comment Share on other sites More sharing options...
Diego Casares Posted March 12, 2015 Report Share Posted March 12, 2015 I want to wire the CUB directly to the lemo 3 pin. I already have one like that and works perfect. Any ideas about how to wire it? It should be the same as for the senny's SK50 Quote Link to comment Share on other sites More sharing options...
Gary V Posted March 17, 2015 Report Share Posted March 17, 2015 I want to wire the CUB directly to the lemo 3 pin. I already have one like that and works perfect. Any ideas about how to wire it? It should be the same as for the senny's SK50 Diego, We are working on building one this week and will get back to you with more info. Gary Quote Link to comment Share on other sites More sharing options...
Diego Casares Posted March 19, 2015 Report Share Posted March 19, 2015 Thanks a lot Gary. I am still looking for an answer to this, so any help would be great Quote Link to comment Share on other sites More sharing options...
Miles Anderson Posted June 26, 2017 Report Share Posted June 26, 2017 I never did see the pinout for the PHA48.. does anyone have that? it isnt in the MTP40S manual. Quote Link to comment Share on other sites More sharing options...
Apcki Posted July 8, 2019 Report Share Posted July 8, 2019 Curious, has anyone soldered a cub to lemo 3 for zaxcom zmts? Quote Link to comment Share on other sites More sharing options...
AlexQ Posted July 19, 2019 Report Share Posted July 19, 2019 On 7/7/2019 at 10:56 PM, Apcki said: Curious, has anyone soldered a cub to lemo 3 for zaxcom zmts? "It Depends" I'm sure its possible but I cant seem to find the specs on the sanken website about its operational voltage. BH give me 3-14 so I would assume yes for now. Quote Link to comment Share on other sites More sharing options...
