Mark Vesterskov
Show me your bag
1,452 posts in this topic
cool snow setup - I still hope SD will release a tactile wireless control interface that works like the wingman app, but with physical controls.
Until they do you could try these:
http://www.tunadjgear.com
Although I do wonder how well those things stay on
My latest update, 411s' powered by NP-1 633 powered by np970s'
On 1/30/2017 at 2:14 PM, PalmerT said:
Edit, are there any plastic loops on the bottom for a harness clip or just the 2 on top?
No I don't need loops on the bottom because it has a built in waste band/strap. But is does have molle if you pefer to use the bottom part of your harness instead of built in straps. Those straps can be tucked into the bag their is a compartment to hid them if you dont use them. I know for the ktek harness you would have to have bottom loops but for the others you can just use the bag strap it acts as the bottom half of the harness. Which I like cause then I add side pouches to the mole for my transmitters (Picture below).
I've been using this "lite" kit more and more these days.  At this point it can cover most jobs as long as the client is ok with the ISO tracks being delivered separate from the pre-mix.  I can fit it all on my back so its easy to get to and from gigs on the crowded subway.
Wow, Michael! Everything in one rucksack - that's kind of great concept!
If you upgrade to a 633 or Max you can do almost anything up to three lavs with this one bag. What is the blue box in the middle? It has a BNC connector and an 1/4 TRS.
Yeah. RX200. Haha. I have another Nomad bag that I use for bigger jobs. It's pretty much the same Zaxcom kit that several folks have posted here. In Shanghai, I've been taking a lot of corporate and web doco jobs. Folks tend to be fine with a stereo deliverable (I charge less) so I was tired of the Nomad overkill (Back kill) kit. Haha. Switched to this kit using the Zaxcom Camera Link as my recorder and ISOs/backups on the TXs and it's really working out for me. If I used a MAXX then I couldn't power it with the Sony L batts and would not be able to fit the kit in the backpack. It's all about fitting everything I need in that pack. A fun challenge!
Are you triggering the TRXs into record from the CameraLink or just manually setting them and let them run continuously?
Hello Sound Ninja!
20170219-22 Having Fun up north in Mont Tremblant, Québec!
What is in the bag :
Sound Devices 664 4.01
3x Lectrosonics Srb (1 x bloc 22 + 2 x bloc 24)
1x Lectrosonics 411 receiver (for boom (not on the picture))
1x Sennheiser HD25II
1x PSC Antenna distro
1x BDS Energy distro
1 Np1 (in the bottom pocket)
1x Comtek transmitter (not showing on the picture, usefully next to the PSC)
1x empty space, for a next to come, SRB bloc 22 :)))))
My first attempt in Zaxcom. So far so good!
and Ktek stingray jr... what an amazing bag. Heavy but great!
Be careful that Zax stuff is contagious.
Love my Stingray Junior as well.  I have a similar setup to yours (2x SRb's) BUT with a SD 633.  Curious, why does your SRb screen's look different than usual?  What's up with those boxes on the screen?
Just now, Glen Deakin said:
TX timer mode.
Ah mystery solved.  Thanks.
I picked up my Zaxcom QRX200, 2x TRXLA2 and the AudioRoot vmDBOX today. I feel like i finally have a serious rig now. :) (i had/have 2x Sennheiser EW100's). Very happy with this new setup, although because i dont have zaxnet i have to manually jam the tx's everytime i power them up.
Other items: Cinela Pianissimo, OSIX 2, MINIX CCM, Schoeps CMC6MK41, CCM41, Panamic pole, PSC travelpole, 2x Sennheiser EK300 for director, K-tek Harness, Tentaclesync. I power everything with a V-lock accu in the K-tek bag.
For your second QRX, get a 235 w/ QIFB. That way, you can jam your transmitters with Zaxnet, control gain and frequency from the QRX's and use ERX's. That's how I run my 633 bag.
Been awhile since my last post... My current setup. Squeezed the Nomad12 in a Ktek stingray junior bag. 🙂
Whoa! How did you do that?! Did you have to cut any of the material? Any chance on a closer picture?
Nope, no cutting involved except that it is very snugged. Just fixed a monitor into it even. 😁
2 hours ago, Auxbusreturn said:
How do you like your UR5's?  Using them with UR1m's?
UR5's are awesome. I'm using mostly UR1, I was told UR1 sounds better than UR1M. I only use the UR1M when I have to for wardrobe. But IDK, I haven't personally done critical analysis to compare both. The UR5 saved my hinnie last week with the auto scan. Took 1 min to scan/find/set correct freq.
