VASI Posted May 30, 2012 Report Share Posted May 30, 2012 Hello to all. I have six audio tracks ready mixing from Pro Tools. L, R, C, Ls, Rs, LFE. What programm use for encoding this files and create one file to put in DVD Architect 5.0? Thank you very much. Vasileios Quote Link to comment Share on other sites More sharing options...
ccsnd Posted May 30, 2012 Report Share Posted May 30, 2012 compressor Quote Link to comment Share on other sites More sharing options...
MatthewFreedAudio Posted May 30, 2012 Report Share Posted May 30, 2012 Does your audio have to be married to video? If so, I would give the PCM files back to the editor or whomever is handling authoring the DVD and it will be encoded along with thr video. Compressor is a good tool if you are encoding the files yourself. Production Sound Mixing for TV, Film, and Commercials. www.matthewfreed.com Quote Link to comment Share on other sites More sharing options...
VASI Posted May 30, 2012 Author Report Share Posted May 30, 2012 Does your audio have to be married to video? If so, I would give the PCM files back to the editor or whomever is handling authoring the DVD and it will be encoded along with thr video. Compressor is a good tool if you are encoding the files yourself. Production Sound Mixing for TV, Film, and Commercials. www.matthewfreed.com Yeap. I need to "married" audio files (L, C, R, Ls, Rs, LFE) with the video in DVD Architect 5.0. It's mine project. But I don't know what programm to use to create 1 file (AC3) and I put in Audio Track in DVD Architect. Thank you very much! Quote Link to comment Share on other sites More sharing options...
MT Groove Posted May 30, 2012 Report Share Posted May 30, 2012 As others have mentioned. Compressor will do the trick. It used to be bundled with apple Final Cut Studio, probably still is. Quote Link to comment Share on other sites More sharing options...
dcsimon Posted May 30, 2012 Report Share Posted May 30, 2012 since DVD architect is only available on the windows platform, maybe a windows compatible program will be better suited here. Minnetonka makes plugins that will encode to DTS and Dolby Digital from within Pro Tools: http://www.minnetonkaaudio.com/ Dolby Digital is essentially AC3, there is a freeware app for windows that will encode AC3 files ready for dvd authoring: http://code.google.com/p/wavtoac3encoder/ Quote Link to comment Share on other sites More sharing options...
VASI Posted May 30, 2012 Author Report Share Posted May 30, 2012 Thank you very much Dana Simmons! Quote Link to comment Share on other sites More sharing options...
VASI Posted May 30, 2012 Author Report Share Posted May 30, 2012 Usefull tip: The file's it must be in 48kHz and 16bit. Because the white noise is here. Quote Link to comment Share on other sites More sharing options...
Mike Kujbida Posted May 31, 2012 Report Share Posted May 31, 2012 Brand new member here who signed up to answer this question. Since you or the person you're doing this for has DVD Architect, they should also have Sony Vegas which can easily do 5.1 creation for DVD. I've been using Vegas for several years and have done a few 5.1 DVDs with it. Mike Kujbida Quote Link to comment Share on other sites More sharing options...
VASI Posted June 5, 2012 Author Report Share Posted June 5, 2012 Thank you Mike for response! Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted June 5, 2012 Report Share Posted June 5, 2012 In Sony DVD Arc Pro 5.2; (latest build 135) the audio file need not be embedded in the Video, it just needs the same base 'file name' AND reside in the same folder as the video file(s) when importing to DVD Arc. So an <.ac3> 5:1 audio file from PTs or elsewhere should work. Quote Link to comment Share on other sites More sharing options...
