TRX 900 with rechargeable NiMH plus setting levels right
Matthias Richter
Hi there,
are you using your Zaxcom TRX 900 with rechargeable NiMH (1.2V) batteries? It says in the manual its best to do so. But even with fresh loaded ones I only get half way on the trx display (the receiver rack unit says T9 so - fully loaded)
and second: what is in your experience a proper level on the trx? I can`t see when the limiter is kicking in (its ON) so I don`t know if I`m wasting too much headroom for safety. I would gess somewhere between -20 and zero should be fine?!
Thanks for your thoughts and help, Matthias
