Travis Prater Posted July 5, 2012 Report Share Posted July 5, 2012 I just got my Nomad 6 the other day, and have been going through it with a fine-toothed comb. I noticed today that on both the Slate and Com, when using the internal mic, there is a fairly low-level "jitter" that sounds a bit like Timecode or something similar. As I figured it was a little late to <HAT>, I figured I would throw this out the the JW Community to see if anyone else has the same thing on their Nomad. Attached is a sample of the noise. Let me know what you think! Thanks in advance. Best, -Travis Prater Nomad Slate Noise.wav Quote Link to comment Share on other sites More sharing options...
rich Posted July 5, 2012 Report Share Posted July 5, 2012 sounds like noise caused by the processors or something like that. but why are you worrying? its a low level noise on the slate mic - it only needs to be intelligible. you can use the slate mic input on the side if you need pristine. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted July 5, 2012 Report Share Posted July 5, 2012 Unless that barely percetable noise is on your tracks all the time I wouldn't worry about it. Eric Quote Link to comment Share on other sites More sharing options...
Travis Prater Posted July 5, 2012 Author Report Share Posted July 5, 2012 I agree, definitely not mission-critical. I just wanted to see if this was something out of the ordinary or a sign of something else that's wrong. I'll be calling the mothership tomorrow. Thanks. Quote Link to comment Share on other sites More sharing options...
OneLouder Posted July 6, 2012 Report Share Posted July 6, 2012 It's on mine too. but listening back to the file on a cpmputer it's not there. Maybe it's just on the headphone feed on the nomad? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted July 6, 2012 Report Share Posted July 6, 2012 I agree, definitely not mission-critical. I just wanted to see if this was something out of the ordinary or a sign of something else that's wrong. I'll be calling the mothership tomorrow. Thanks. That's not anything to be worried about, unless it's (like Eric said) in your tracks all the time. I have a similar issue that is MUCH worse than that with my 552 (B-return has return audio and also Timecode - when there's nothing coming in the return I can hear very quiet timecode in my headphones) but it's still not a problem. The sound that you're hearing is not Timecode BTW, it sounds more like a clock signal for a battery meter or, like Rich said, processor squeal. Quote Link to comment Share on other sites More sharing options...
glenn Posted July 6, 2012 Report Share Posted July 6, 2012 It is normal for the internal slate mic to pick up a little internal noise. Nothing to be concerned about. Glenn Quote Link to comment Share on other sites More sharing options...
Travis Prater Posted July 6, 2012 Author Report Share Posted July 6, 2012 Thanks everyone, I appreciate the feedback. I guess I'm being a little over-cautious. Quote Link to comment Share on other sites More sharing options...
mastermixaudiomedia Posted July 6, 2012 Report Share Posted July 6, 2012 I remember reading somewhere the noise is due to the slate mic wiring's physical routing within the Nomad's internals. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted July 6, 2012 Report Share Posted July 6, 2012 I remember reading somewhere the noise is due to the slate mic wiring's physical routing within the Nomad's internals. From the manual Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted July 7, 2012 Report Share Posted July 7, 2012 Who here is using an external slate mic? What are you using? I will be working on a cart for a month soon, and I am thinking about rigging a senn. Lav on my headphone cable so I don't have to lean into the nomad for slate/comms. Quote Link to comment Share on other sites More sharing options...
rich Posted July 7, 2012 Report Share Posted July 7, 2012 I have a sennheiser lav in my nomad slate and it works very well. Quote Link to comment Share on other sites More sharing options...
