Yelmarb Posted August 2, 2012 Report Share Posted August 2, 2012 I'm trying to pull apart a 4 pin Hirose plug but I've not got very far with it. Just doesn't seem to be anything obvious past the screw-on crimping collar. Is there some trick with the spring loaded outer collar or is there another part I need to unscrew? Quote Link to comment Share on other sites More sharing options...
Simon Hayter Posted August 2, 2012 Report Share Posted August 2, 2012 Now you need to plug it into something and unscrew the body from the plug with a spanner (wrench?) or pliers. Those flat sides above the knurled bit. Good luck Quote Link to comment Share on other sites More sharing options...
Tom Visser Posted August 2, 2012 Report Share Posted August 2, 2012 A correction, you are looking at a Hirose connector, not Lemo. (Japanese v Swiss) Quote Link to comment Share on other sites More sharing options...
Yelmarb Posted August 2, 2012 Author Report Share Posted August 2, 2012 Brilliant, thanks guys. Quote Link to comment Share on other sites More sharing options...
RandyHall Posted August 2, 2012 Report Share Posted August 2, 2012 Yeah, the only way I've gotten into a Hirose is to have a jack to use as an anchor to hold the plug while unscrewing the retaining nut. Kinda a pain, but once you're in there, it's easier than a LEMO. Quote Link to comment Share on other sites More sharing options...
Yelmarb Posted August 13, 2012 Author Report Share Posted August 13, 2012 A little further down the line with this. Are you guys using a special crimping tool on these Hirose crimps (pic attached) or just a pair pliers? Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted August 13, 2012 Report Share Posted August 13, 2012 I've done plenty without, but if you have a crimper die for rg58, that works nicely. Quote Link to comment Share on other sites More sharing options...
Yelmarb Posted August 13, 2012 Author Report Share Posted August 13, 2012 Cool, I do have that RG58 hex crimper in fact. Sweet, I'll give that a try Quote Link to comment Share on other sites More sharing options...
jonathan chiles Posted October 8, 2012 Report Share Posted October 8, 2012 The Hirose connectors with the chuck type strain relief as in OP work.. I have had no luck using the brass crimp collar strain relief and grub screw in Yelmarbs last post.. for me that is a terrible system to try and line up and I just end up filling the connector with epoxy to hold everything in place and stop the wires and pins twisting. Quote Link to comment Share on other sites More sharing options...
Soundbite Posted October 17, 2012 Report Share Posted October 17, 2012 @Yelmarb, pliers worked for me, but becareful not to send the barbs into the cable. Jons right as well - takes a bit of trial and error to line the crimp up properly. All the same I think its an improvement on the old style one. Quote Link to comment Share on other sites More sharing options...
