Doug Brandon Posted September 24, 2007 Report Share Posted September 24, 2007 I did some simple searches on the site and could not find... What is the original definition of ADR? I've always thought it was down the lines of (pun unintentional) Audio Dialogue Replacement, or Recording. But I just finished watching our fearless governator in the orig TERMINATOR and there was a credit for 'Additional Dialogue' by William Wisher, jr. Is the AD for ADR? Up too late for any goodness, Doug Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted September 24, 2007 Report Share Posted September 24, 2007 I recall it as meaning "Automatic Dialog Replacement." This makes reference to not having to use the previous tedious method -- known as "looping" -- of playing back a physical loop of film repeatedly until a good take is recorded onto mag stock. With the advent of SMPTE time code and microprocessor controlled auto-locaters on tape decks and video decks, the newer process was "automatic" by comparison. Someone correct me if this isn't accurate. John Blankenship Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 24, 2007 Report Share Posted September 24, 2007 I recall it as meaning "Automatic Dialog Replacement." This makes reference to not having to use the previous tedious method -- known as "looping" -- of playing back a physical loop of film repeatedly until a good take is recorded onto mag stock. With the advent of SMPTE time code and microprocessor controlled auto-locaters on tape decks and video decks, the newer process was "automatic" by comparison. Someone correct me if this isn't accurate. John Blankenship That's how I know it, with the joke being that the original ADR was far from "automatic", it just meant that you didn't have to cut loops of mag film anymore. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Noah Timan Posted September 24, 2007 Report Share Posted September 24, 2007 I recall it as meaning "Automatic Dialog Replacement." This makes reference to not having to use the previous tedious method -- known as "looping" -- of playing back a physical loop of film repeatedly until a good take is recorded onto mag stock. With the advent of SMPTE time code and microprocessor controlled auto-locaters on tape decks and video decks, the newer process was "automatic" by comparison. Someone correct me if this isn't accurate. I believe it was "Automated", actually, but it's essentially the same thing. Quote Link to comment Share on other sites More sharing options...
syncsound Posted September 24, 2007 Report Share Posted September 24, 2007 IIRC, William Wisher did some additional dialogue writing (and also has a cameo in the mall scene in T2). -Christian Quote Link to comment Share on other sites More sharing options...
Alien Posted September 25, 2007 Report Share Posted September 25, 2007 At Pinewood, looping was used for years, then around 1982 we got some ADR (Automated Dialogue Replacement) machines from Magna Tech put in to Theatre 5. It took a bit of getting use to but once the new system was up and running it made the sound camera ops job a hell of a lot easier. I didn't have to splice the loops into reels anymore. No quick loop changes on the run down of the Westrex machine, and I could even get a bit of a nap in if the tea was a bit late. Quote Link to comment Share on other sites More sharing options...
