Zack Posted November 13, 2012 Report Share Posted November 13, 2012 Or this: Quote Link to comment Share on other sites More sharing options...
api Posted November 13, 2012 Report Share Posted November 13, 2012 The latest firmware on Scarlet (V3.3.14) also has a documented change: "Fix Audio meter to show real peak". I am not sure what that means. I also noticed that the minimum value for audio level in adjustment is now +15dB. It used to be +8dB in the previous firmwares, I think. It is now impossible to compensate for the line level out on a Pix 240 without using a line to mic level pad on the cable. That is even when using the -20 dB adjustment on the Pix menu for audio output pad value. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 13, 2012 Report Share Posted November 13, 2012 " I have found that on 7xx recorders "Free Run" is more stable TC-wise than "24h Run". " how were you able to determine this ?? while the internal TOD clock is not as accurate as the TC clock, once that time is jammed into the TC clock (24 hour mode), the TC clock is just as stable as if you entered (jammed) any other value. Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted November 14, 2012 Report Share Posted November 14, 2012 " I have found that on 7xx recorders "Free Run" is more stable TC-wise than "24h Run". " how were you able to determine this ?? Determined this the hard way, getting complaints from post about TC sync not matching sticks over the day. Used Free Run instead of 24h, problem solved. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 14, 2012 Report Share Posted November 14, 2012 " getting complaints from post about TC sync not matching sticks over the day. " that is pretty vague, though more problem solving would seem appropriate to actually determine the root cause as has been authoritatively reported the actual TC generator is the same, runs tyhe same,... discussions with <cap>, perhaps on the SD users' support forum would be appropriate, as if there is some problem I'm certain SD would also like to resolve it. Quote Link to comment Share on other sites More sharing options...
petesmith Posted March 25, 2014 Report Share Posted March 25, 2014 I realise this thread is a bit old now but I have a shoot coming up with a red scarlet with the pro i/o module and I have a ACL 202 lockit box and I had a question that could do with some of your expert knowledge. Am I right in thinking I jam the lockit from the 744t (5-pin lemo to 5 pin lemo cable) and then jam the scarlet from the lockit - for this do I need a BNC to 5-pin lemo or can this be done just with the 5-pin lemo to 5 pin lemo cable if I have the pro i/o module? Any advice is greatly appreciated, Pete Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted March 25, 2014 Report Share Posted March 25, 2014 I realise this thread is a bit old now but I have a shoot coming up with a red scarlet with the pro i/o module and I have a ACL 202 lockit box and I had a question that could do with some of your expert knowledge. Am I right in thinking I jam the lockit from the 744t (5-pin lemo to 5 pin lemo cable) and then jam the scarlet from the lockit - for this do I need a BNC to 5-pin lemo or can this be done just with the 5-pin lemo to 5 pin lemo cable if I have the pro i/o module? Any advice is greatly appreciated, Pete Typically, you jam the Lockit from the 744T - that's right. But you would not typically jam sync the Scarlet (or any camera, maybe except for the Alexa) from the Lockit, but set the Scarlet to EXT TC and leave the Lockit on it all the time, "continuously" feeding TC to the cam. That way you make sure it stamps the first frame of each file recorded with the TC received from the Lockit (and that way the same TC that the 744 has). So picture and sound are never more than just below one frame off. For more accurate sync you'd also have the Lockit feed Tri-Level into the cam. Quote Link to comment Share on other sites More sharing options...
petesmith Posted March 25, 2014 Report Share Posted March 25, 2014 Great, thanks pkautzsch for the quick response. I shouldn't have used the word 'jam' as thats not what I meant. I know you have to leave the lockit connected to the camera I was just wondering how you connect the lockit to the scarlet when using the pro i/o module? 5-pin lemo to 5-pin lemo? or BNC to 5-pin lemo? Quote Link to comment Share on other sites More sharing options...
petesmith Posted March 25, 2014 Report Share Posted March 25, 2014 I'll make sure I set the scarlet to EXT TC in the menu though. Cheers for the tip. Quote Link to comment Share on other sites More sharing options...
Constantin Posted March 25, 2014 Report Share Posted March 25, 2014 I was just wondering how you connect the lockit to the scarlet when using the pro i/o module? 5-pin lemo to 5-pin lemo? or BNC to 5-pin lemo?yes, 5-pin lemo to 5-pin lemo. For additional genlock you'd need a simple bnc-bnc cable. Quote Link to comment Share on other sites More sharing options...
Constantin Posted March 25, 2014 Report Share Posted March 25, 2014 Determined this the hard way, getting complaints from post about TC sync not matching sticks over the day. Used Free Run instead of 24h, problem solved. i know this is old news now, and you've probably long since figured this out, Peter, but maybe someone else will benefit: you TC differences probably happened when you switched your 744T off for lunch or whatever, and then switched it back on again thereby prompting it to sync again to the less accurate time of day clock which by then would be a bit off from you last sync Quote Link to comment Share on other sites More sharing options...
petesmith Posted March 26, 2014 Report Share Posted March 26, 2014 great! thanks Constantin. Quote Link to comment Share on other sites More sharing options...
petesmith Posted March 26, 2014 Report Share Posted March 26, 2014 Did a test today and it seemed to work perfectly. What I did was: made sure lockit and 744t were set to the right frame rate, set 744t to free run -> got timecode into lockit (ACL 202) with 5 pin lemo-to 5 pin lemo -> removed from 744t and plugged into scarlet pro i/o module -> in scarlet menu went: settings -> project ->timecode ->external rear module and that seemed to work. Hopefully this was all right? Thanks for all the advice and the useful posts. Quote Link to comment Share on other sites More sharing options...
