jgbsound Posted July 1, 2016 Author Report Share Posted July 1, 2016 On 8/16/2012 at 3:13 AM, jack coghill said: just to be controversial, I have used PRO AUDIO DSP's 'Dynamic Spectrum Mapper' for this task (match EQ), and had great results.. http://www.proaudiodsp.com although mostly I also just use EQ and a bit of reverb and sometimes slapback delay Jack Hey Jack! Just checked out Pro Audio's DSP Dynamic Spectrum Mapper (I watched the video anyway). That's really impressive. I'm going to download the trial and try it out! Thanks for the recommendation. John Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 1, 2016 Report Share Posted July 1, 2016 There are other plugs that attempt the same thing. If it works for you, great. My experience was that I spent just as much time trying to get the plug to do its job as I would just trying a match with EQ etc, and the results were comparable. The advantage to the old school method is that usually the EQ etc settings are automated, and thus tweakable later on as the mix gets built. The EQ match plugs were not something I wanted to run "live" under automation in a mix. Quote Link to comment Share on other sites More sharing options...
jgbsound Posted July 1, 2016 Author Report Share Posted July 1, 2016 I totally agree Phil. I was mainly interested in the "differencing" of the EQ settings as a reference, more so than having a plugin magically fixing my EQ/compression issues. What I'd prefer is a software that gave me the comparison and allowed me to apply the EQ accordingly and tweak as I see fit, rather than just applying an algorithm to "fix" my problematic areas. I thought was that this plugin appeared pretty comprehensive in the way that it could allow you to "learn" and apply it elsewhere to fix certain issues. Mainly the DeEssing and adjusting for different recording feeds (Since I did a fair bit of ADR in this mix). If you know of a software that just analyzes an area and reports a suggested change (EQ-wise) I'd love to know about it. That's my ultimate goal. John Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 1, 2016 Report Share Posted July 1, 2016 The Voxcengo "Curve EQ" shows you what it's doing to try and make a match http://www.voxengo.com/product/curveeq/. I still found the match just ok and time consuming, but it kind of does what you were talking about re: showing what it's doing. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted July 2, 2016 Report Share Posted July 2, 2016 And I believe iZotope RX Advanced also has some kind of an "EQ Match" mode where it will take two files of the same thing and EQ one to match the other. I have yet to try it, but the principles look good on paper. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 2, 2016 Report Share Posted July 2, 2016 Izo doesn't tell you as much about what it's doing, what freqs are in play. I didn't find that feature of RX5 useful at all..... Quote Link to comment Share on other sites More sharing options...
jgbsound Posted July 2, 2016 Author Report Share Posted July 2, 2016 This is true. I have iZotope's EQ match in RX5 advanced and it simply learns the envelope and applies it often causing unwanted problems. I finally gave up on using it. I'll look at the app you mentioned Phil. Ultimately I'd just like a starting point to perform my own EQ tweaks. I do all my EQing in automation anyways so it's flexible. Amazing how one day I can really like my EQing and the next I change it again. Quote Link to comment Share on other sites More sharing options...
Constantin Posted July 4, 2016 Report Share Posted July 4, 2016 I sometimes used Roger Nichols Freqal-izer Match EQ part with some success. Sometimes it didn't work at all, but it does show you fairly clearly what it's doing. Not sure if they still make it, though Quote Link to comment Share on other sites More sharing options...
conleec Posted October 7, 2016 Report Share Posted October 7, 2016 I've used Melda's Dynamic EQ to do this. It has a matching feature, and I use it to help get ADR in the pocket. https://www.meldaproduction.com/MAutoDynamicEq Quote Link to comment Share on other sites More sharing options...
jgbsound Posted October 7, 2016 Author Report Share Posted October 7, 2016 Thanks for the suggestion, I'll give it a try! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 7, 2016 Report Share Posted October 7, 2016 One old trick or method is that you often have to make the boom sound "worse" to get it to match.... Quote Link to comment Share on other sites More sharing options...
Micah Loken Posted October 7, 2016 Report Share Posted October 7, 2016 3 hours ago, Philip Perkins said: One old trick or method is that you often have to make the boom sound "worse" to get it to match.... The phrase that comes to mind here is - "you're only as good as your weakest link" In this case, the weakest link is often the lav. So, muddying up the boom a bit never hurts to try. Sounds like a lot of people have bad experiences with automatic EQ matching tools. As a rule of thumb, I use iZotope's EQ match first, and then if that fails (no plugin will be perfect), then I use the 'ol ears. Either way, it goes back to fixing, listening, and repeating as many times as time allows in order to achieve the desired result. In my opinion, it is the job of the editor to help his fellow man (the mixer) down the line by attempting to make his life easier. Over processing does not help them though so it is always good to be as minimalistic in the editorial phase, unless you are going to be mixing your own edit. Quote Link to comment Share on other sites More sharing options...
