Nomad AES in, Sonosax AES out, routing the mono mix
Jobo
Howdy,
I'm hoping for some technical guidance running a console mixer in front of a Nomad 8. I'm setup using both AES inputs and analog input on nomad to accomplish a post fade mono mix, and pre fade ISOs down the line.
The setup is Sonosax 84 AES out -> Nomad AES in.
Ch 1-8 digital out on sonosax is post-eq, pre-fade signal.
That feeds directly to Digital in 1-8 on Nomad.
The Sonosax digital out is ONLY pre-fade, post eq. In order to get a post fader signal I must run an analog bus (XLR) out of Sonosax and into analog input 1 to Nomad.
This solves my routing a mono mix to the Nomad, my question is this.
Am I facing any factors in delay or latency with this setup and A/D conversion? Recording to Card using Digital & analog inputs simultaneously, does anyone else have experience with this?
I notice no delay between the mono mix track and the pre fade track on Nomad with this config, but I'm not sure on the science end of it.
This is a new setup for me, any constructive suggestions/criticisms are welcome.
Thanks,
Jobo
