Zaxcom- MAXX
glenn
Well, wahoo for you dude! Thanks for pointing that out. It's still an issue for the rest of us though. The reason why I brought this up was that Glenn first presented this unit as something that simplifies the bag by requiring less cables etc. The problem is, adding the IFB 100 to the equation (vs Nomad) keeps the cabling about the same.
Both the Nomad and Maxx provide a more simplified bag than the competitors for sure, so before all you Zaxcom fanatics get all defensive, as I said before I think it's going to be a great unit regardless. Still would be great to offer a an ERX that could be tuned to the Maxx TX block though.
I currently have a Fusion 12, IFB100, and various Zaxcom wireless for hops and cast. I think this new Maxx is going to be a perfect small mixer to compliment my other rig! So, while some are bemoaning the lack of built in IFB I am thrilled with the feature set. I'll just pull out the IFB100 when needed...and being paid for by the client. I plan on buying the full blown Maxx next year when the need arises.
Production Sound Mixing for Television, Films, and Commercials.
www.matthewfreed.com
it won't be a problem that if you use QIFB as the wireless mic though,you can use that to control zax-gain.
You can do the same through the IFB 100, but that's the point everyone is making - you cannot use MAXX faders to control the preamp gain, or the rec button for remote roll etc like you can with Nomad/Fusion/Deva.
there are only four faders on the panel,one for boom and two for lavas, it's pointless to use the last fader to control one of the zax-gain.Even with Nomad it's not convience enough to actually seeing the zax`-gain number changes right now.
if you use MAXX with single camera for a rec-run tc setup,the camera link QIFB can be the master get tc from camera then slave your lava QIFB,then the lava QIFB's tc output to your MAXX to slave the MAXX.
if you use MAXX as the master clock for multi cameras,you can send tc though built in transmitter to couple or several camera QIFB to slave or the camera's tc. ( the QIFB can receive TX's tc as main tc source)
the ifb100 just would be a extra weight in your bag.
my wondering is : if we have AES option and transmitter option,does it have the ability to transmit four ch(post fader output level) to one QRX ,Glenn ?
100mW sounds great
No. That would require a second stereo transmitter. That was a question above - you would use AES outputs to feed a second hop tx.
Only the D4 sends 4 channels with 1 transmitter so far...
Of course, but not controlling the TX preamps via faders, slave transport etc etc. But who knows.
...probably Glenn.
Was I not clear in my post? The answer is No. I asked the <hat> this question prior to posting.
It's kinda too bad there's no zaxnet, but its clear the Maxx is the Maxx and the Nomad is something else.
"I'd be happy to admit I'm wrong..?"
I also don't know of a single 4 channel transmitter besides the D4...Cloud?
"there are only four faders on the panel,one for boom and two for lavas, it's pointless to use the last fader to control one of the zax-gain.Even with Nomad it's not convience enough to actually seeing the zax`-gain number changes right now."
I don't know if I'd use the word "pointless.". The znet page gain control on the Nomad is pretty coarse right now, but this is "on the list" of things being addressed (according to the <hat>). Using one of the faders (assigning a tx gain in the fader menu) yields quicker adjustments, and though there is no numerical feedback, you can more or less guess based on the position of the dial!
The Maxx display will be easier to read in direct sun than the Nomad as we have eliminated the plastic covering that is part of our button panel. The Glass display is excellent in the direct sun.
The IFB100 can be used with Maxx. I see no reason why the Maxx would not provide recording control over our wireless if the time code connection was utilized but I need to talk to Howy on that. If the Zaxnet capabilty is importaint a Nomad 6 is the best choice.
Glenn
Glenn
So it comes with the 'Knife Mod' already performed? I'm confused. If the plastic cover isn't useful on Nomad why do we have it? And if it does prevent dirt and moisture entering the device or becoming engrained on the surface will the Maxx be more vulnerable?
The whole ERX thing requires 2.4 Ghz rf transmission and Maxx does not have any 2.4 Ghz wireless. Also, it seems to me that so many posts here are already starting to complain about what Maxx doesn't have. If Maxx were the only product from Zaxcom, this would be a concern, but since there is already the hugely successful Nomad for lightweight portable bag use, Maxx fills out the product lineup in a really good way. If the job requires things that Maxx cannot do (like full Zaxnet and IFB, infinite I/O routing, etc.) then use Nomad. If Nomad lacks things you want (like touchscreen, more I/O, higher track count) the use a Deva. We have really gone so far off from the one-size-fits-all recorder/mixer because of fundamental changes in the jobs we do. Also, if you are at a place in your career where you want to be able to do ALL sorts of jobs recording sound, you're going to need a wider variety of equipment these days.
don't get too serious about my post Justin and Greg,i have tons of zaxcom products at home,and actually probably more than any one in this post.
it's still half a year of time,i think if we want some features( eg:more ch be transmitted or built in ifb),we should let Glenn know about it. So they can consider add it or not.
for me: the four ch digital transmission would be awesome. I think it's not that hard for zaxcom to add two more TX ch. It's only the number of ppl who ask for it.
Yes you will have Zaxnet transmission from the camera via QRX100 with IFB option. QRX100 will transmit camera audio and camera time code or Maxx time code that it receives from the Maxx via the UHF transmission. As pointed out the range will be excellent due to the transmitting position on the camera.
Again the Nomad is always an option if complete Zaxnet control is required.
So a perfect system might be Maxx, QRX100 with IFB option for the camera and ERX2 monitor receivers.
Glenn
Just bought a Nomad.
Bugger.
Would have been nice to know this was round the corner. Built in camera hop would be great on Nomad...
Here's the thing, you are using the Nomad today. The Maxx isn't coming for at least 8 months. They are still pretty different devices in terms of features, though I agree a built-in camera hop would have been really cool for Nomad. Not sure I would want to lose Zaxnet for it. If I am doing a 5D or Red shoot (and some other camera setups), I only send a reference track to camera. When it's not a 5D, I am often using a sync box too. In that case, the Zaxnet mono track + TC option is perfect.
Glenn
This is basically what I do now with Fusion. Im curious to hear from Howy, what software functions might be possible still (your past comment).
I don't understand why you would pick the maxx over a nomad if you had the option
It's a smaller, lighter box, and it's cheaper.
There are a lot of us that own/owned a 302 and a 442. I bought my 302 after owning a 442 and to this day think it was a great purchase. Actually, I use my 302 more than the 442 these days. If I am going to use more tracks, I use my Nomad.
