Philip Perkins Posted October 2, 2007 Report Share Posted October 2, 2007 OK, who has heard this? Where does it fall sound wise re: Senn/Sanken/Neumann/Schoeps? Philip Perkins Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted October 2, 2007 Report Share Posted October 2, 2007 Only heard it at NAB (and we have all discussed that issue already) --- it will definitely be a contender in the same league as the Sanken CS3e and the Schoeps CMIT (with a little bit of the Sanken CS-1 although that may be just psychological because of the size / weight factor). I am hoping for some direct experience of my own or from someone who can actually do some work with it (I know that's what you're asking and I'm not giving a good answer!). - Jeff Wexler Quote Link to comment Share on other sites More sharing options...
Fernando Posted October 6, 2007 Report Share Posted October 6, 2007 Looks good. I'm curious about it's rolled-off lows (70 Hz) Since it's a DPA that may not be a problem and the thing sounds great, let's see. It's pretty sensitive too (30 mV/Pa) It could be great if they release a shorter Windpac for it (and other mics) so you can be closer of the sound source, it is just 21 cm long. A 4017 together with a shorter Windpac can make a very transparent and very light shotgun rig... ok and expensive too Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 6, 2007 Report Share Posted October 6, 2007 ...hope it would be better the schoeps which sorry waist of my partner money :-) I assume you're talking about the CMIT? What don't you like about it? Thanks, John Quote Link to comment Share on other sites More sharing options...
