jonathan chiles Posted October 8, 2012 Report Share Posted October 8, 2012 I need to make up a line to mic 1/8" mini to 1/8" mini plug cable for a friend. The output is a Tascam DR100 recorder consumer level line output feeding a 5D Mkii Mic Input. Any pointers for wiring in a resistor pad would be appreciated.. Mr Toline?? Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted October 8, 2012 Report Share Posted October 8, 2012 Hey Jon! Try this: It's a 10dBu to mic level, 40dB pad + input with a 10K in series 100ohm in parallel between + output and ground. (in where the 100ohm is wired on the output side of the 10k) Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted October 8, 2012 Report Share Posted October 8, 2012 Wyatt types faster than I do ;-)) Eric Quote Link to comment Share on other sites More sharing options...
jonathan chiles Posted October 9, 2012 Author Report Share Posted October 9, 2012 Thanks guyz Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 9, 2012 Report Share Posted October 9, 2012 For those wanting to learn a little bit about audio circuits: A 10:1 ratio is -20dB, a 100:1 ratio is -40dB, and a 1,000:1 ratio is -60dB. NOTE: These are voltage ratios, power ratios are different. Quote Link to comment Share on other sites More sharing options...
Picazoaudio Posted December 21, 2014 Report Share Posted December 21, 2014 Hi (Mari Mari): This can be useful Bye (Pewkayal) Quote Link to comment Share on other sites More sharing options...
