Dave Rae Posted October 26, 2012 Report Share Posted October 26, 2012 I recently noticed that one of my two block 21 rx's has lost range compared to the other. I tested them simultaneously - both on the same freq with a single um200c tx then with tx off. One rx is picking up more RF than the other (with tx off) as well as more hits at a closer range with the tx on. Any ideas? Other tests? Also the proximity to my Nomad seems to affect the range of my block 21 systems. David Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 26, 2012 Report Share Posted October 26, 2012 (edited) Hi, and welcome... " Any ideas? " beyond troubleshooting 101, needs a tune-up Edited October 26, 2012 by studiomprd Quote Link to comment Share on other sites More sharing options...
aristotle_kumpis Posted October 26, 2012 Report Share Posted October 26, 2012 If it's affecting the performance quite a bit, then you should send them to Lectrosonics. Quote Link to comment Share on other sites More sharing options...
jason porter Posted October 26, 2012 Report Share Posted October 26, 2012 Pilot tone bypassed? Or just broken? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted October 26, 2012 Report Share Posted October 26, 2012 For valid testing, first eliminate all variables: Swap antennas, swap physical positions of the receivers, swap batteries or power leads, etc., anything that might affect your results. Quote Link to comment Share on other sites More sharing options...
Dave Rae Posted October 26, 2012 Author Report Share Posted October 26, 2012 For valid testing, first eliminate all variables: Swap antennas, swap physical positions of the receivers, swap batteries or power leads, etc., anything that might affect your results. Thanks guys. I'll test some more along these lines but will probably have to bite the bullet and send it to Lectrosonics for the tune-up. (I'll post on the Nomad RF block 21 effects later on.) Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 26, 2012 Report Share Posted October 26, 2012 " I'll test some more " be sure you follow the double secret, ultra master reset sequence. Quote Link to comment Share on other sites More sharing options...
Dave Rae Posted October 28, 2012 Author Report Share Posted October 28, 2012 " I'll test some more " be sure you follow the double secret, ultra master reset sequence. I'm suppressing that compulsion to tinker (and self educate) and will avoid searching for a DSUMRS this time around... Quote Link to comment Share on other sites More sharing options...
