Peter Mega
Aquapac
Definitely not in the second one, only the Sma/SQMV at a squeeze will fit in that. I don't have a UM to check with, but a TRX900 with a Block 26 antenna just fits in the newest one (top) - so I'd say the UM with block 26 antenna would be too tall to fit without the antenna being bent.
Edit: I think you'll need this one http://store.aquapac.net/connected-electronics-558-30.html
Edit: I think you'll need this one http://store.aquapac...ics-558-30.html
Incorrect.
I own three of this type and they fit my 2020 transmitters, which are larger than UM400. The fit is snug, but it keeps the whole size of the thing down (they are awkwardly sized anyway).
The previous version of the same size is much, much tighter. I've had them from hire companies and found it incredibly difficult to extract the TXs from. They seem to have changed the design slightly and made them roomier.
Thanks Larry. Good to know.
I have some of the new swivel type aerials which came with my SMQV so they will be perfect in the Aquapac but I'll still have to use some regular aerials too.
Cheers
Peter Mega
Incorrect.
Okay, great. I must have some of the older design. Cheers.
Hi Pete
I have the 548 and really they are only dunk proof. Had too many leaks to safely use submerged. The two openings double the risk of a leak.
If you haven't bought call and I can sort you out.
Chris
Hi Pete
Chris
The website specs say the same thing - submersible for short periods only. I always put the transmitter in a non-lubed condom as well.
What's your solution, Chris?
Don't use submerged. I wouldn't trust a condom to do what the aquapac can't do. Also remember the Tx will not transmit under water. At risk of quoting "it depends"
Oh, the condom is only there for if a tiny leak makes it in the aquapac. Which has never happened, and I've only employed them for 'risk of dunk' shots, not 'definitely in the water' shots. If that was happening, I'd be looking at hiring a MM or WM. Or, you know, booming from a boat/pontoon etc.
I use Zax radios - so even if they don't transmit underwater, they can still record. (as long as they don't get fried!!)
Thanks.
Hi Chris.
I've already bought. I need 14 so thought I'd bite the bullet.
How many do you have, in case mine don't arrive in time.
They won't (hopefully) be submerged, it's for contestants walking out to a boat at low tide through sloshy mud.
Cheers
Peter
So, What do we do if we need to submerge to tx underwater? I'm going to shoot a doc about a big waves surfer, in places like Jaws, or Pipeline, and I'm researching how to record the surfist while he rides the waves. I thought about having two aquapacks around a Zaxcom ZFR100 recorder, but for sure they'll be crushed under huge waves, so would they work in such a situation?
Thanks
Hey guys.
Did you have to take off the belt clip to make it fit in the Aquapac 548?
I can see from your pics that the freq sliding door cover assembly is still on so the width looks fine.
Thanks
Peter
