Ryan Farber Posted November 27, 2012 Report Share Posted November 27, 2012 I have recently been experiencing odd noises coming from my G3 receivers. The noises sound digital in nature, its not static or RF interference. I noticed that the noise is only apparent when the backlight on the screen of the receiver turns off. When you press a button to wake the screen back up again the noise goes away. The noise is also synchronous with the the little LCD display, in other words, when something moves on the display (like the audio level indicator) when the backlight is off, you hear the little digital artifacts. It is very odd, and very annoying. I recorded a sample of the noise. The first part is the noise by itself, with the lav on the transmitter muted. The second part is the noise with the lav on, and how it reacts when there is sound going through. Anyone have any ideas? Here is the link to the audio file. Quote Link to comment Share on other sites More sharing options...
Ryan Farber Posted November 27, 2012 Author Report Share Posted November 27, 2012 I figured it out. I feel like an idiot. The input the G3 was plugged into on my 442 had T-power on. That was for some reason amplifying the digital noise coming from the Lav. Quote Link to comment Share on other sites More sharing options...
chrisnewton Posted November 27, 2012 Report Share Posted November 27, 2012 don't feel bad Ryan. I had a problem years ago when I plugged a Sony RF receiver into my 442. sounded bad, no low end, kind of pinched sounding. couldn't figure it out. sure enough: T-power was switched on. switched it off, problem solved. when I plugged Lectro receiver into same T-powered input there was no problem. balanced (Lectro) vs. unbalanced (G3) the reason? Quote Link to comment Share on other sites More sharing options...
