floodmix Posted January 2, 2013 Report Share Posted January 2, 2013 So far in my sound career I've learned to rely to moleskin, undercovers, and overcovers as the main mic buffering materials, but I was wondering if there are other similar materials people use out there? Sometimes because of the common curve-balls like chest hair, stubble, minimal warddrobe, things like that, I need a small and robust solution that combines the properties of both moleskin and the rycote products. I'm going to experiment with flannel to cut up into small pieces. Also, if I can somehow find the overcover material in a small sheet so I can cut it up as I please, though maybe with shorter hair so its less bulky... Cheers. Quote Link to comment Share on other sites More sharing options...
RFsound Posted January 2, 2013 Report Share Posted January 2, 2013 As far as wind protection goes, I'm always trying to find new, cheaper materials to cover my lavs with. I even tried cutting the fingers off of some cheap Jersey Work Gloves once, but the wind protection wasn't the greatest. Here's the best thing I've found as an alternative for the Rycote Overcover material: go to a local fabric store and ask them for fur (fake, of course) trim. It comes in different color rolls, and you can get them to cut you a short piece to play around with. I found something pretty good at JoAnne's Fabrics. The backing is fairly soft and acoustically transparent and you can shorten the threads (hence less bulky) easily with a scissors. When I run out of stickies, I make my own using either Topstick or Hollywood Fashion tape. Quote Link to comment Share on other sites More sharing options...
floodmix Posted January 4, 2013 Author Report Share Posted January 4, 2013 Awesome, thanks! Quote Link to comment Share on other sites More sharing options...
Sound Art Film Posted January 5, 2013 Report Share Posted January 5, 2013 Corn pads also work well for forward addressed lavs. I also use double sided tape often I think the dpa style cover would work well and I plan on buying them with my future purchase of some 4060's. Quote Link to comment Share on other sites More sharing options...
PelicanSound Posted January 28, 2013 Report Share Posted January 28, 2013 Kinesio Tek tape works as well as transpore.. Quote Link to comment Share on other sites More sharing options...
jason porter Posted January 28, 2013 Report Share Posted January 28, 2013 One trick that I picked here that isn't often discussed- tensor bandage over a hairy chest/sternum (multiple layers) with the lav sandwiched in between the layers. There is the Micbra which attempts to do this, but I don't think it quite works as well. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted January 28, 2013 Report Share Posted January 28, 2013 Mic bra is indeed weak. Buyers regret. Quote Link to comment Share on other sites More sharing options...
Soundwil Posted January 28, 2013 Report Share Posted January 28, 2013 Thanks Jason P. Simple and non destructive (to the hairs) solution. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted January 29, 2013 Report Share Posted January 29, 2013 I had to deal with a hairy-chest situation a couple of weeks ago, and was able to use some Overcovers on the mic and some double-stick tape to hold down the shirt in place. Virtually no issues at all. I let the actor pull off the tape later on, telling him I'd rather he cause himself pain than me causing him pain. I'm not sure there are materials beyond this, though I might try a Hush Lav foam cover next time to see if that makes any difference. In any case, the mic could still pick up "hair on shirt" noise, noise that's not caused at all by mic placement per se. Quote Link to comment Share on other sites More sharing options...
sounddguy Posted January 30, 2013 Report Share Posted January 30, 2013 Mic bra is indeed weak. Buyers regret. Used one this weekend but as a belt. The dress wouldn't allow a bra strap position but pulled around the waist it put the tx in the small of the back where there wasn't anything else substantial to clip to. Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted January 30, 2013 Report Share Posted January 30, 2013 Mic bra is indeed weak. Buyers regret.I thought that too but used one on a male with a light button up up shirt with at least the top three buttons open. The mic was a COS11d which fit nicely into the slot on the strap. We were out on a Zodiac boat so I also used an overcover for wind. The rig worked really well. Didn't get any wind noise or chest hair noise at all until the boat got going really fast and even then the only noise was when his shirt starting flapping. I taped the cable to the back side of the strap with Transpore and used it all week on him. It was a very quick way to wire him up. Most of the shirts he wore were light tee shirts or the lightweight button ups. Glad I brought it along on the trip. Quote Link to comment Share on other sites More sharing options...
