Welcome to JWSOUNDGROUP
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, get your own private messenger, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Zax TRX900LA: which brand of SD card?
  • Please log in to reply
20 replies to this topic
#1
Brian Whitlock
Brian Whitlock
  • LocationBozeman, MT
I have new TRX900LAs and need SD cards.  I recall Zax not liking some brands in the past.  Is this still the case?  Any recommendations on SD card brands?
Brian
#2
Jack Norflus
Jack Norflus
  • LocationBrooklyn, New York
Sandisk transcend or delkin.
4 gb is preferred. 4gb will give you 24 hours of record time.
#3
Michael Miramontes
Michael Miramontes
  • LocationInland Empire, CA
I bought a bunch of cheap one's on ebay. I've been using them for some time now with no issues.
Link to seller.
Michael Miramontes
#4
videomantis
videomantis
  • LocationLos Angeles, CA
Michael,
I do not recommend using anything but what is recommended. I got burned on a job because I used Kingston Cards and they would just randomly stop recording when they felt like it. It also wasn't like they didn't work right out of the packaging either - they worked flawlessly for weeks, and then decided to fail when I was in a remote location where next day Fedex delivery took 4 days..........
~Thomas Popp
Video Mantis
Video Mantis Inc. ~Thomas Popp thomas@videomantis.com
#5
Jack Norflus
Jack Norflus
Caution eBay can be hit or miss. Counterfeit cards do exist and you do get what you pay for.
#6
Michael Miramontes
Michael Miramontes
Michael,
~Thomas Popp
Video Mantis
Hello Thomas,
The cards I bought on ebay are Sandisk Micro-SD cards. I've been using them for 8 months now without any issues.
BTW, thanks a million for all those Zaxcom vids! They really did help me learn the system and gain the confidence I needed to use it properly. That, and the occasional "oh shit, what do I do" phone calls to Jack Norflus. haha
Yeah, I was afraid of that too but haven't had any problems with the cards thus far. The seller I recommended is in the U.S. and they advertise the cards as being 100% Sandisk.
Since they're cheap enough it wouldn't hurt to buy one and try it for yourself. Yes, I agree there is comfort in spending more for something from a brick&mortar store but in this case I haven't had a single problem. =)
Michael Miramontes
#7
Boomboom
Boomboom
  • LocationMontrĂ©al, Canada
Keep in mind that when you use zaxconvert, you deal with the whole capacity of the card so if you got an 8Go card and always use only 1.5Go for your daylies, you're losing some time waiting for the 8Go to unload to the computer so you can after treat the actual files you recorded.
Like Jack mentions; a 4go card will give you 24h of recording so you'd be fine for 2 big days of work on it.
--- Pierre ---
--- Montréal , Canada ---
#8
soundslikejustin
soundslikejustin
  • LocationBrisbane, Australia
I use Sandisk Micro Ultra, 8Gb cards. $20 each.
Justin Harrison
Brisbane, QLD, Australia
#9
Derek H
Derek H
  • LocationChicago
I still wish someone could explain to me why higher capacities should be avoided and why there is a "segment number" limit even if you don't hit the full capacity of the card.
#10
soundslikejustin
soundslikejustin
Higher capacities don't need to be avoided, they're just not that necessary. As for the segment limit, that has to do with the formatting of the MARF system in the transmitters - basically it pre-allocates 255 segments or positions for data to fill. This is also why your card is 'full' when you format it in a TRX, and why there's a delete.me file on there too - it's pre-allocating space for an update file.
The file size doesn't matter, but the start of each segment is given a unique identifier, and once you've used as many segments as the system can handle, it can't make any more. It's quite different to 'normal' computing file systems.
Justin Harrison
#11
Boomboom
Boomboom
What's been said, if there's a downside to having a high capacity card, is that if you don't upload/save your files on a regular basis you risk losing more data if the card fails.
Apart from that I don't remember reading more technical explanations that would lead to problems having higher capacity cards.
Same in the photography world.
--- Pierre ---
#12
videomantis
videomantis
Michael, Thanks for the compliments on the videos! ~Thomas Popp Video Mantis
#13
Derek H
Derek H
  • LocationChicago
Thanks Justin, I do understand that the segment limit is due to the proprietary MARF file system but I dont understand the significance of 255. Why not 999 or 9999?
As far as I know the Deva, which also uses the MARF system, doesn't have any such file segment limit.
#14
Jack Norflus
Jack Norflus
The segment limitations has nothing to do with MARF. Its actualy 254 segments and it has something to do the the size of the card and I can't remember the exact reason.
#15
soundslikejustin
soundslikejustin
254 is pretty close to 256, which is the maximum level of 'steps' in 8 bit code... It may not be a function of MARF per se, but there's no such limit on 'normal' FAT32 formatted disks.
edit: well, there is a limit on FAT32 clusters (a cluster is up to 32KB, a FAT entry uses 4bytes), but its 268,435,445.
Justin Harrison
#16
Derek H
Derek H
  • LocationChicago
Anyway, I just don't get it.
#17
Johnathan Sessoms
Johnathan Sessoms
  • LocationOrlando, FL
Thanks for all this info. I was going to start a thread asking about these, but now I know. I bought 32gb cards on ebay for my fusion. I got extremely lucky because they're a random brand from a random place and they work flawlessly.
Sessoms
#18
airport70
airport70
  • LocationLondon
I use Transend 4gb class 4 cards on a show running up to 12 TXs every day over 7 weeks and they've been flawless,  I'm also very weary of fakes, I actually called of UK HQ to find reputable suppliers.
#19
Tom Duffy
Tom Duffy
Are you sure they're flawless?
Here's what really happened in counterfeit or knock off sold state devices in the past :
The required number of physical flash chips is missing.
The firmware on the controller is tweaked to show that writes are working correctly when they are going into space.
Reads just pull something random from the existing chip.
Worse - the writes can all go to the one chip - overwriting something already there and most likely destroying the file system.
These cards seem to work fine for the first couple of weeks before data starts to get sent out to the non-existent flash chips.
This kind of counterfeit is less easy to do now because there is usually only one memory chip in there - just different capacities.
But, the problem still exists when that flash chip is deliberately mislabeled as a higher capacity part.
How often do you destroy your SD cards to check that the flash chip capacity matches the model capacity?
Most people just think it's an early life failure, and throw it out when their computer reports errors with it.
There is no limit to the ends that knock-off manufactures will go to to squeeze their costs down when there there are no real consequences (no warranty, no class action lawsuits).
Buy brand name, buy from a reputable dealer, one less thing to worry about in your gear bag.
Tom.
#20
studiomprd
studiomprd
  • LocationHollywood CA
because.
" Anyway, I just don't get it. "
no need to.
SENATOR Mike Michaels, c.a.s.
Studio M Productions
#21
Michael Miramontes
Michael Miramontes
because.
no need to.
LOL...
"because"
man, you're killing me Mike.. :lol:
Michael Miramontes
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
