sepulchra
Bumblebee Lav Windscreens
I'm just curious if folks have been using these windscreens:
http://www.bhphotovideo.com/c/product/835680-REG/Bubblebee_Industries_BBI_L02_BK_Windbubble_Miniature_Imitation_Fur.html
I have been using rycotes but I haven't been totally happy with the way the work with DPA4060s.
Thanks,
Michael
I've used these on COS-11 and TL40. Tricky to get on sometimes, but very effective.
I had one on a freeskii style downhill skier doing crazy jumps and tricks. i had some pretty impressive results considering! I've never tried the Rycote, so not sure how it compares.
cheers!
I use them from time to time. As mentioned, they can be very tricky to get on sometimes. They're also very bulky. I've had instances where showing a lav is acceptable and when I wanted to use the bubblebee I was asked not to. Just too distracting - like a big giant bug on someone's shirt.
With that said, they are fairly effective. I've also wired up a skydiver using one and as they approached the ground the wind noise was almost non existant. Pretty impressive.
I think they're just another good tool in the toolbox. Not for everyday use, but when you need it you'll be glad you have it.
I use the product with Sony ECM 77s'and they work quite effectively, just give yourself a little time to fit them ....if I have the time I will slip them over the Sony metal windscreen for a real nice fit, but they are equally effective just over the capsule! JHW
