Hissy recording with female voice? SD 302 + Avantone CK1 + Marantz 661
swaneon
The female voice is not hissy, she has a high frequency peak in her speech on "S" sounds. It will always be there. Best you can do is to minimize it by doing what others have suggested. FWIW, I don't find it objectionable.
Eric
I agree with Eric, as far as hyper-sibilance goes, this is quite mild.
Try cutting 2-3dB at around 7K with a very narrow Q.
Best
avantone ck1
http://www.avantonepro.com/Avantone-CK-1-Small-Capsule-FET-Pencil-Microphone.html
"The high quality FET circuitry will yield pleasing professional results comparable to much more expensive designs. Any studio can proudly offer the CK-1 for instrumental and percussion mikingIt exudes class visually as well as sonically. The CK-1 is equally at home on the stage for drum overheads, acoustic instruments and piano."
Specifications
Type
True Condenser
Polar Pattern(s)
Cardioid , Hyper-Cardioid & Omni Capsules included
Frequency Response
25-20,000 Hz +/- 3dB
Output Impedance
<=200 Ohms
Maximum SPL
138dB (0.5% THD @1000Hz)
Sensitivity
15mv/pa
S/N Ratio
1Pa 78dB
Noise Floor
< 17 dBA
Output Connector
Male XLR 3-pin
Included Accessories
-3 Capsules
-Padded Wooden Box
-SSM Shockmount
High-Pass Switch
80 Hz 6dB/octave
Attenuation Switch
-10 dB
Power Requirements
Standard 48 Volt Phantom / 5mA
Dimensions
(23mm) x (153mm)
Weight
5 oz.
Finish
Polished Nickel trim / Metallic Cabernet Red Body
$149 everywhere
"The female voice has a hissy quality that annoys me and destroys the audio"
- By "hissy", do you mean sibilance or the BG noise floor?
- I concur with Eric, it does not sound all that bad to me. A lot depends on ones playback speakers (and D/A converter) if they're not at least somewhat accurate, you don't know what your heariong. Computer speakers for instance are notorious for a  'hissy' sound
" Any studio can proudly offer the CK-1 for instrumental and percussion mikingIt exudes class visually as well as sonically. The CK-1 is equally at home on the stage for drum overheads, acoustic instruments and piano."
what sounds good for drum overheads,acoustic instruments and piano might not best flatter the human voice, be it male or female
I heard that the avantone was good but now I'll probably look for other mics--schoeps or sennheisher
by hissy I mean the sibilance---her peaks when she pronounces her "S" seems very sharp--
from what others mentioned is that naturally with some people's voice or is that a technical issue?
I would also say that background hiss is a combination of matching the characteristics of the microphone and the preamp, plus it depends on the mic's own self-noise issues. To me, you can't expect a lot from a $150 Chinese-made microphone. (I know of some older low-output American and European dynamic mics that weren't exactly quiet, too.)
Try a lower-noise condensor mic like the Sennheiser MKH40 (sensitivity of 25mv, noise level of 12dB), and you'll hear a big difference. If this is for music vocals in a booth (vs. production), then I'd consider getting advice over on the Gearslutz Forum, which has literally thousands of discussions on vocal mics for music recording.
