Jack Norflus Posted April 19, 2013 Report Share Posted April 19, 2013 The new camera link beta testing has officially begun. Quote Link to comment Share on other sites More sharing options...
r.paterson Posted April 19, 2013 Report Share Posted April 19, 2013 Hello jack, can you test out the auto load on the cam ink, my trx900aa was back to zaxcom s few times getting checked but was always erratic in auto load fine in auto or manual..thanks..Richard Quote Link to comment Share on other sites More sharing options...
Derek H Posted April 19, 2013 Report Share Posted April 19, 2013 I thought it was already out of beta test? Hopefully this doesn't mean it's still months away. I see they're sticking with the edge lit screen of the current transmitter. Quote Link to comment Share on other sites More sharing options...
Mark Posted April 19, 2013 Report Share Posted April 19, 2013 Put an order in today for one. I hope it does not take months either! Looks like a good test for any rf spray from the positioning in that bag. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted April 19, 2013 Report Share Posted April 19, 2013 I thought it was already out of beta test? Hopefully this doesn't mean it's still months away. I see they're sticking with the edge lit screen of the current transmitter. Perhaps it keeps rf down a bit? Backlit lcds can make a lot of noise and rf.. Or have I been dreaming? Quote Link to comment Share on other sites More sharing options...
TimPitot Posted April 19, 2013 Report Share Posted April 19, 2013 lets see some scans on those RX's Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 19, 2013 Author Report Share Posted April 19, 2013 I thought it was already out of beta test? Hopefully this doesn't mean it's still month away Nope this is the final stages of beta testing for software tweaks. The actual unit is already in production. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 19, 2013 Author Report Share Posted April 19, 2013 lets see some scans on those RX's I will post photos over the weekend but the scans I did with my 411s in blocks 25 and 26 with the transmitter at 100mW and being that close the spray was almost non existent. There was extra attention paid to the spray issue and it appears like it paid off. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 19, 2013 Author Report Share Posted April 19, 2013 Here are scans of my Lectro 411a receivers. 2 receivers on block 25 and 2 receivers on block 26 Zaxcom camera link on block 21. Camera link transmitter power set at max output level at 100mW. I went to my garage - because it is the part of my house that has the least RF. I fired up the 411's and scaned. Without turning off the 411's then I fired up the camera link (frequency was chosen at random) Quote Link to comment Share on other sites More sharing options...
Derek H Posted April 19, 2013 Report Share Posted April 19, 2013 Looking good ! Of course at 4 blocks away I should hope so! Regardless of block It's good that you're able to operate it so close to the receivers. Same power supply I assume as the 411s? IFB transmitter powered up, and at what power? BDS or other type? I'd like to see this with a block 20 or 22 receiver. Thanks Jack! Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 19, 2013 Author Report Share Posted April 19, 2013 Everything powered off a common NP1. The BDS is a very old Peter Engh BDS - which he made for me back around 1997. ZaxNet turned on - at this point in the software there is no adjustments on ZaxNet level so it is full up. Even though they are several blocks apart there is SIGNIFICANTLY less spray from the Camera Link than from my TRX900AA with STA. Sorry can't try other blocks since I don't own them. Though if there is someone in NY with those blocks let me know and we can test them. I also intentionally put the Link close to the 411's - for my normal operations I would have a bit more separation. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted April 20, 2013 Report Share Posted April 20, 2013 What is "full up" zaxnet tx power on the cam link finally? Quote Link to comment Share on other sites More sharing options...
pscottm Posted April 20, 2013 Report Share Posted April 20, 2013 i'm wondering if the same recommended block spacing applies to the CL? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted April 20, 2013 Report Share Posted April 20, 2013 i'm wondering if the same recommended block spacing applies to the CL? I'd presume so. Remember, the Camera Link is two blocks wide. I would NOT want either of those blocks in or directly next to my RX blocks. Quote Link to comment Share on other sites More sharing options...
glenn Posted April 20, 2013 Report Share Posted April 20, 2013 Zaxnet power will be between 50mW and 100mW final results will be known in about 3 weeks. Yes the link needs 1 block in between the operating frequency and the bag receivers. Since the TRX900CL operates over 2 blocks it is more flexible than our previous offerings as it utilizes switched filters to minimize the noise floor. The more blocks you can have in between the better. Glenn Quote Link to comment Share on other sites More sharing options...
studiomprd Posted April 20, 2013 Report Share Posted April 20, 2013 " Nope this is the final stages of beta testing for software tweaks. " Jack: we've been there before... haven't you learned ? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted April 25, 2013 Author Report Share Posted April 25, 2013 First full day using the Zaxcom Camera Link. And the link performed like a champ - I had output level running at 100mW and I had rock solid RF performance with no real RF spray. And the best feature is its form factor. It is so much better than the TRX900AA with STA - mounting in a bag is so easy and takes up much less space. Quote Link to comment Share on other sites More sharing options...
PTA Posted April 25, 2013 Report Share Posted April 25, 2013 First full day using the Zaxcom Camera Link. And the link performed like a champ - I had output level running at 100mW and I had rock solid RF performance with no real RF spray. And the best feature is its form factor. It is so much better than the TRX900AA with STA - mounting in a bag is so easy and takes up much less space. That's great news. So very tempting... Quote Link to comment Share on other sites More sharing options...
r.paterson Posted May 3, 2013 Report Share Posted May 3, 2013 Hello jack, just wondering if you managed to test the auto load function ie with camera in record run and triggering the camera link recorder, I haven't had any success with my trx900aa/sra150 in auto load , drops out half way thru recording erratic performance, it is however rock solid on manual and autijam..thanks..richard Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 4, 2013 Author Report Share Posted May 4, 2013 Hello jack, just wondering if you managed to test the auto load function ie with camera in record run and triggering the camera link recorder, I haven't had any success with my trx900aa/sra150 in auto load , drops out half way thru recording erratic performance, it is however rock solid on manual and autijam..thanks..richard I have not - generally I don't use auto load in my work flow. But I will test this and get back to you. Though the handfull of times i used it with my 900AA/STA I never had an issue. Were you in and out of range of the camera and it lost TC? Quote Link to comment Share on other sites More sharing options...
cameronlenart Posted May 4, 2013 Report Share Posted May 4, 2013 Would I be able to feed one ERX via Nomad and another ERX via Camera link giving me two separate audio feeds? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted May 4, 2013 Report Share Posted May 4, 2013 Would I be able to feed one ERX via Nomad and another ERX via Camera link giving me two separate audio feeds? Yes, assuming you sent two different signals to the Nomads IFB and the Camera Link, and the 2.4ghz transmitters were both on different channels. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 4, 2013 Author Report Share Posted May 4, 2013 Or you can do what I'm doing - transmit with one and receive with the other. Quote Link to comment Share on other sites More sharing options...
Cloud Wang Posted May 4, 2013 Report Share Posted May 4, 2013 Hello jack, just wondering if you managed to test the auto load function ie with camera in record run and triggering the camera link recorder, I haven't had any success with my trx900aa/sra150 in auto load , drops out half way thru recording erratic performance, it is however rock solid on manual and autijam..thanks..richard Both of my sta150/trx900 works very fine on auto-load from receiving camera rec-run tc all the time via QIFB on camera. The tc cable on camera's qifb the signal is on the 3.5mm's ring Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 5, 2013 Author Report Share Posted May 5, 2013 Hello jack, just wondering if you managed to test the auto load function ie with camera in record run and triggering the camera link recorder, I haven't had any success with my trx900aa/sra150 in auto load , drops out half way thru recording erratic performance, it is however rock solid on manual and autijam..thanks..richard Richard Ran auto-load through its paces today and I can report that it passed with flying colors. Quote Link to comment Share on other sites More sharing options...
