soundslikejustin Posted May 22, 2013 Report Share Posted May 22, 2013 $2350 according to PSS. Quote Link to comment Share on other sites More sharing options...
TimPitot Posted May 23, 2013 Report Share Posted May 23, 2013 Oooof. Any cheaper for non recording & IFB models? Quote Link to comment Share on other sites More sharing options...
Wyatt Tuzo Posted May 23, 2013 Report Share Posted May 23, 2013 Wyatt - I believe the with the Lectros after the first scan any new RF will be added that scan. Regardless I did the test your way with an initial scan and the link powered down. Took a photo. Powered down the lectros. Powered up the link and re-scanned the lectros. My results are basically the same as the initial test. So once again - link on 21 and Lectros on 25 and 26: Whoops. You're absolutely right, Jack. My brain must've been working backwards that day. What I meant was that the Lecro's will not remove anything from the rf scan on subsequent passes... Which has no bearing on your tests either way. My apologies. Best. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 23, 2013 Author Report Share Posted May 23, 2013 Any cheaper for non recording & IFB models? All units come fully loaded. Quote Link to comment Share on other sites More sharing options...
TimPitot Posted May 23, 2013 Report Share Posted May 23, 2013 Thanks Jack Quote Link to comment Share on other sites More sharing options...
Peter Mega Posted May 23, 2013 Report Share Posted May 23, 2013 All units come fully loaded. Can the IFB transmission be switched off, or is it always on? Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted May 23, 2013 Report Share Posted May 23, 2013 Can the IFB transmission be switched or is it always on? Both radios can be switched independently. UHF+Zaxnet, UHF only, Zaxnet Only, Recorder only. Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted May 23, 2013 Report Share Posted May 23, 2013 Thanks Jack Considering its 2 blocks wide, has built in recording, has a 2.4ghz high-level Tx/Rx built in, the equivalent of the filter antenna, and does analogue/digital input it's priced very well, I think. A similar STA setup would cost a lot more. Quote Link to comment Share on other sites More sharing options...
Peter Mega Posted May 23, 2013 Report Share Posted May 23, 2013 Both radios can be switched independently. UHF+Zaxnet, UHF only, Zaxnet Only, Recorder only. Cool. Thanks Justin. I wouldn't want unnecessary rf if I wasn't using it. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted May 24, 2013 Report Share Posted May 24, 2013 I wouldn't want unnecessary recording if I wasn't using it... Quote Link to comment Share on other sites More sharing options...
Actualsizeaudio Posted May 24, 2013 Report Share Posted May 24, 2013 Has there been an update on Zaxnet power? Does it approach the power of an IFB100? Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted May 24, 2013 Report Share Posted May 24, 2013 I wouldn't want unnecessary recording if I wasn't using it... I'm going to guess making all units have the card slot activated means easy firmware updates. Having recording active by default means less models to keep sorted out. Will the Camera Link send firmware updates to an ERX or a QRX or RX900S? With my TRX900/STA150 setup I usually have it on looping record that starts when the Nomad goes into record. It's very rare that I will need that, but it's nice to have. On some jobs I will just let it record whenever the bag is powered up in case my Nomad wasn't recording and something unexpected happens. Again, if it's looping the TRX will overwrite the oldest files ad space is used up, so I always have a recording of the last 24 hours or so that my kit was turned on. Then there are the 302 jobs where it is a very useful feature. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 24, 2013 Author Report Share Posted May 24, 2013 Has there been an update on Zaxnet power? Does it approach the power of an IFB100? The final numbers should be available in about a week. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 24, 2013 Author Report Share Posted May 24, 2013 Will the Camera Link send firmware updates to an ERX or a QRX? Yes Quote Link to comment Share on other sites More sharing options...
Mark Posted June 3, 2013 Report Share Posted June 3, 2013 Any more news?? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 3, 2013 Author Report Share Posted June 3, 2013 Any more news?? They should be shipping soon. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 3, 2013 Report Share Posted June 3, 2013 That was quick! Thanks Jack Quote Link to comment Share on other sites More sharing options...
VASI Posted June 3, 2013 Report Share Posted June 3, 2013 The audio transmission done it via UHF and the IFB plus timecode via ZaxNet 2.4 GHz. Also the RTN (IFB) signal it's from ZaxNet 2.4 GHz. Right? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 3, 2013 Author Report Share Posted June 3, 2013 The audio transmission done it via UHF and the IFB plus timecode via ZaxNet 2.4 GHz. Also the RTN (IFB) signal it's from ZaxNet 2.4 GHz. Right? All correct. Though you can also send TC embeded in the UHF signal. Which would free up the 2.4 for audio return. Quote Link to comment Share on other sites More sharing options...
VASI Posted June 3, 2013 Report Share Posted June 3, 2013 Thank you Jack! Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 8, 2013 Author Report Share Posted June 8, 2013 Has there been an update on Zaxnet power? Does it approach the power of an IFB100? Yes! It will be 100mW. Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 8, 2013 Report Share Posted June 8, 2013 Yes! It will be 100mW. That's cool. Will it have all the other ifb features like transmitter remote control? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 8, 2013 Author Report Share Posted June 8, 2013 That's cool. Will it have all the other ifb features like transmitter remote control? No the ZaxNet transmission / reception will only be for audio and tc. Quote Link to comment Share on other sites More sharing options...
Jobo Posted August 8, 2013 Report Share Posted August 8, 2013 Just received mine yesterday. It is a big improvement aesthetically as well as functionally. And it finally solves most of the RF spray problem, happy day. I can't say that all your cables will plug and play. BDS cable for STA100 yes, but I have a problem with the remote audio cable (left and right) TA3 to TA5 input for STA100. I'm coming out of the TA3 stereo bus on a 552 and can only get to -25 or so on ch1 of the new camera link with the trim cranked all the way up. If I swap out the CL for the old trx900/sta100 I get unity @ normal -20db. So there maybe similar issues with anyone trying a similar setup, or I just have bad luck with new equipment. I'm going to swap the TA3 cable for an XLR y cable later today to see if I can get matching input levels in this thing. Quote Link to comment Share on other sites More sharing options...
Cloud Wang Posted August 8, 2013 Report Share Posted August 8, 2013 my sonosax M32 output a nice signal that i can get -20 dB on my CL. But i did feel that even the tone level are the same on the CL and STA/TRX, the CL's general sound recording level is slightly lower. i have to say i miss that LED light on top of the TRX which can tell me the unit is in recording or not. On CL it's too hard to read that 900LA type screen when operating in a bag. And since zaxcom didn't put an internal batt in the CL,it does NOT hold the TC after power off which is very very very odd decision. anyway you have to use a external lockit or zax-IFB feed its TC all the time if you use timecode. and one more thing, as an zax IFB unit, the CL does not have the ability to remote control GAIN on any zax-TX units yet ( so far v1.25) the IFB on CL is good, better range than the one in the QIFB,higher mW output. gets heat like other zax TX.RX. Quote Link to comment Share on other sites More sharing options...
