James Arnold Posted June 9, 2014 Report Share Posted June 9, 2014 When mounted the top of Nomad the opening is sealed when it is attached. I get that Jack, but how sealed is it? Is the underside of the unit completely open to the electronics? Water has a way of getting through even tight cracks. Obviously the Nomad itself is not water tight, but I would worry about brief rain showers and general dust that could make its way inside. Howy is planning on making the functionality of the function key user assignable. We like this! Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 9, 2014 Report Share Posted June 9, 2014 Using the Nomad's top plate as the bottom plate for the fader panel means less additional weight. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted June 9, 2014 Report Share Posted June 9, 2014 Make the plate top or bottom friendly then... Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted June 9, 2014 Report Share Posted June 9, 2014 Less bulk too. Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted June 9, 2014 Report Share Posted June 9, 2014 The FP8 was designed to be mounted to the top of Nomad - though you can potentially do a DIY bottom mount. There are two things that need to be done. First there no metal on the bottom of the FP8 so you would need to fashion something to close the unit. Secondly you would need to make sure you have a good physical ground between Nomad and the FP8. Given that Glenn has mentioned if there is enough interest he would design a kit that would allow you to mount the FP8 on the bottom of Nomad - or even elsewhere in the bag. I personally like it mounted on the top. Thanks for clearing that out! Personally, I originally thought that having the FP8 on the bottom would be best for my configuration, due to it having more faders than the Nomad, the transport buttons, and it putting a bigger physical gap between the Nomad and my body in a bag (which I sought). Now, I'm not really sure that it matters. I kind of like the idea of having the bigger faders closer to me. That said, I think having the choice is better than to not having it. But, either way, I know that I would love this in my bag! Quote Link to comment Share on other sites More sharing options...
mastermixaudiomedia Posted June 11, 2014 Report Share Posted June 11, 2014 Looking good. Might be the next piece of Zaxcom in my world domination kit! BTW just got in a QRX200 and TRXLA2 today... Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 11, 2014 Report Share Posted June 11, 2014 First production unit Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted June 11, 2014 Report Share Posted June 11, 2014 First production unit Sweet! Looking forward to getting one soon Quote Link to comment Share on other sites More sharing options...
Jason Todd Posted June 11, 2014 Report Share Posted June 11, 2014 Rado, are you going to try to make room for the fader panel or are you not planning on getting one? Quote Link to comment Share on other sites More sharing options...
TimB Posted June 11, 2014 Report Share Posted June 11, 2014 Looks real nice! Are the faders smaller on the FP8 or is that just an illusion? Planing a 2-fader version for the Maxx maybe?.. This makes me want to get a Nomad... Damn... Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 12, 2014 Report Share Posted June 12, 2014 An FP2 and / or an FP4 I think would be well received. I personally don't know what I would do with 8 more knobs but that's just me. Nomad 10 Here. Quote Link to comment Share on other sites More sharing options...
Nathaniel Robinson Posted June 12, 2014 Report Share Posted June 12, 2014 +1 for Maxx sized FP4, although without a serial port I'm not sure it's possible. While I'm dreaming, it also does my invoicing. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 12, 2014 Report Share Posted June 12, 2014 Looks real nice! Are the faders smaller on the FP8 or is that just an illusion? Planing a 2-fader version for the Maxx maybe?.. This makes me want to get a Nomad... Damn... Yes the knobs are slightly smaller. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 12, 2014 Report Share Posted June 12, 2014 I personally don't know what I would do with 8 more knobs but that's just me. Nomad essentially has 18 inputs - 10 analog and 8 digital. Will you need/use all of these inputs at the same time? Probably not. But you can set up the FP8 faders to fade any one of the 18 inputs as well as control transmitter gain, or adjust input faders. So 14 hardware faders can get used up pretty quickly. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 12, 2014 Report Share Posted June 12, 2014 No question, if I had a handful or more zaxcom transmitters, so useful and powerful to be able to control them from the FP8. I would just like to have better control over channels 7-10 on the jobs I need to. A limited functionality FP2 and or FP4 would be great. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted June 12, 2014 Report Share Posted June 12, 2014 Nomad essentially has 18 inputs - 10 analog and 8 digital. Will you need/use all of these inputs at the same time? Probably not. But you can set up the FP8 faders to fade any one of the 18 inputs as well as control transmitter gain, or adjust input faders. So 14 hardware faders can get used up pretty quickly. Should be noted you can't use more than 12 inputs simultaneously. I expect the fader panel will be a great addition. I also think a half width panel will be more awkward to mount in the bag, so even if all the faders aren't being used, it will still be a nice addition. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 12, 2014 Report Share Posted June 12, 2014 I also think a half width panel will be more awkward to mount in the bag. Where there is a will there is a way. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted June 12, 2014 Report Share Posted June 12, 2014 Where there is a will there is a way. Fair enough Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted June 12, 2014 Report Share Posted June 12, 2014 +1 for Maxx sized FP4, although without a serial port I'm not sure it's possible. While I'm dreaming, it also does my invoicing. IIRC the Nomad originally going to get a 4 pot add-on module, and over time that idea evolved into this. I think this would be easier to use. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 12, 2014 Report Share Posted June 12, 2014 Arg, well, I will purchase an FP2 in a heartbeat. And if it could be ganged with another FP2, I would buy a second! Quote Link to comment Share on other sites More sharing options...
TimB Posted June 12, 2014 Report Share Posted June 12, 2014 A FP2 could just be a small 2-fader preamp with zaxcom style knobs, 2 XLR IN and a TA5 output. That would be great for me atleast. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted June 12, 2014 Report Share Posted June 12, 2014 No prefade iso's with something like that. Quote Link to comment Share on other sites More sharing options...
RScottATL Posted June 12, 2014 Report Share Posted June 12, 2014 Tim B Kortwich makes this exact product (close enough, not exact). No need to wish. Order one today. Look for the thread about the Kortwich VCP-M3 fader preamp. Quote Link to comment Share on other sites More sharing options...
Jason Todd Posted June 12, 2014 Report Share Posted June 12, 2014 You could also try the RX emergency 2. http://www.reddingaudio.com/cable-techniques-rx-emergency-two.php Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted June 16, 2014 Report Share Posted June 16, 2014 Is the underside of the unit completely open to the electronics? Water has a way of getting through even tight cracks. No it is not open. It is closed. Quote Link to comment Share on other sites More sharing options...
