Alexa audio record in high speed (slow-mo)?
After searching all the Alexa threads here and reading the manual I have a quick question which remains unanswered.
Does the Alexa record the audio inputs when it's frame rate is increased for slow-mo shots? I seem to remember a reference to the audio being 'blocked' (not recorded) when this happens but cannot find anything about it.
Thanks.
It doesn't record audio if the frame rate is different to the project frame rate (not sure if you can put high frame rates as project rate)
You cannot change the project frame rate to anything higher than 30fps with current firmware. Audio is disabled for any frame rate different to the project rate.
