Glen Deakin Posted December 24, 2015 Report Share Posted December 24, 2015 Has anyone had a chance to work with the remote audio low profile connectors? How are they for assembly strain relief and positions of the cable. Thanks. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted December 24, 2015 Report Share Posted December 24, 2015 Sound Guy solutions also makes a low profile XLR and TA5. I just got some of the TA5 connectors but havent had a chance to solder then yet. They are serviceable and pretty low profile (will post photos when I get a moment). I plan on picking up some of the XLRs as well. Quote Link to comment Share on other sites More sharing options...
Jeremiah Sheets Posted December 24, 2015 Report Share Posted December 24, 2015 On December 22, 2015 at 9:53 AM, Simon Hayter said: Well, you were right Matt. I got a reply from Neutrik basically saying 'not a chance' ! Not very helpful. Those Remote Audio ones look good though Ha! Actually I find that pretty helpful. It's good to know that you definitely should look elsewhere. Quote Link to comment Share on other sites More sharing options...
efksound Posted December 24, 2015 Report Share Posted December 24, 2015 Not as nice and pro looking as the connectors from OPS but here is my version, screwable & serviceable as well :-) Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted December 24, 2015 Report Share Posted December 24, 2015 They look great! Quote Link to comment Share on other sites More sharing options...
Shastapete Posted December 24, 2015 Report Share Posted December 24, 2015 Gotham sound makes a 3D printed version too Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted December 26, 2015 Report Share Posted December 26, 2015 Here is the sound guy solution TA5. The cap is beautifully machined and the connector is servicable. I don't have any of their XLR connectors but they are very similar. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted December 26, 2015 Report Share Posted December 26, 2015 Can't find the caps on their website. Can you post a link? Quote Link to comment Share on other sites More sharing options...
Gene Martin Posted December 26, 2015 Report Share Posted December 26, 2015 We currently don't have them up on the Sound Guys Solutions website, but here are a few pics that I have on me at the moment. Still working on getting colored inserts manufactured, but we've done some custom laser engraved options as well. Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted December 29, 2015 Report Share Posted December 29, 2015 On 12/26/2015 at 11:32 AM, Gene Martin said: We currently don't have them up on the Sound Guys Solutions website, but here are a few pics that I have on me at the moment. Still working on getting colored inserts manufactured, but we've done some custom laser engraved options as well. These look great Gene! Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted December 29, 2015 Report Share Posted December 29, 2015 How do you order them and is there a TA3 available. Thinking for my Lectro LR receivers. They look great! Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted December 30, 2015 Report Share Posted December 30, 2015 1 hour ago, berniebeaudry said: How do you order them and is there a TA3 available. Thinking for my Lectro LR receivers. They look great! I got my TA5 connectors from the Audio Department directly. The Sound Guy Solution connectors use the standard switchcraft pin base (not sure if that is the offical name). So if you bought the connector and just used the metal shell and and end cap without the 5 pin base - depending on the cable used - you can get away without even re-soldering the cable. All you would need to do is just open your current TA3, remove the metal strain relief and discard it. Then physical cut off the switchcraft plastic boot - you can probably just squeeze the boot with a plier and it would just crack off. Then the TA3 pin base and little plastic ring that is already soldered would just slide into the SGS metal shell and put on end cap and you are done. Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted December 30, 2015 Report Share Posted December 30, 2015 2 hours ago, Jack Norflus said: I got my TA5 connectors from the Audio Department directly. The Sound Guy Solution connectors use the standard switchcraft pin base (not sure if that is the offical name). So if you bought the connector and just used the metal shell and and end cap without the 5 pin base - depending on the cable used - you can get away without even re-soldering the cable. All you would need to do is just open your current TA3, remove the metal strain relief and discard it. Then physical cut off the switchcraft plastic boot - you can probably just squeeze the boot with a plier and it would just crack off. Then the TA3 pin base and little plastic ring that is already soldered would just slide into the SGS metal shell and put on end cap and you are done. Thanks Jack! I'll need to convert to a smaller cable anyway. The Lectro LRs came with cables but they're made of the larger diameter cable. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted December 30, 2015 Report Share Posted December 30, 2015 3 minutes ago, berniebeaudry said: Thanks Jack! I'll need to convert to a smaller cable anyway. The Lectro LRs came with cables but they're made of the larger diameter cable. I've been using the mogami 2967 reciently and I can easiely fit a pair of thr 2967 into the connector. Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted December 30, 2015 Report Share Posted December 30, 2015 16 minutes ago, Jack Norflus said: I've been using the mogami 2967 reciently and I can easiely fit a pair of thr 2967 into the connector. Good to know. I just looked at the cables I have and they're not as heavy as I was thinking. They're Belden 9397 miniature flexible mic cable. The existing connector is Switchcraft so that's a plus too. I just looked at the diameters and the 2967 is 2.5mm in diameter and the 9397 is 4.47mm. Do you still think the right angle cap will work with my existing cable? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted December 30, 2015 Report Share Posted December 30, 2015 I think it should. You can always file a bit of the metal shell if it's too tight. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted January 18, 2016 Report Share Posted January 18, 2016 Sound Guy Solution TA5 right angles. Super easy to work with and they are completely serviceable. Quote Link to comment Share on other sites More sharing options...
Derek H Posted January 18, 2016 Report Share Posted January 18, 2016 Cool! Gene can you share pricing info for what you currently have available? Quote Link to comment Share on other sites More sharing options...
Governor Posted February 29, 2016 Report Share Posted February 29, 2016 Apologies for my ignorance - but when making multiple of these and combining them in a bag how are you binding all the cables together? I'm new making cables other than a simple XLR or BNC and wonder what people are using to tie 6 cables together? Quote Link to comment Share on other sites More sharing options...
Jeremiah Sheets Posted February 29, 2016 Report Share Posted February 29, 2016 Maybe the Senator can delegate with you on this one. (Bad joke, don't care.) I use small velcro strips to attach them to the inside of the bag together. Easy to separate when needed. I know I have a dedicated post, but it doesn't hurt to add here: These were made for me by Audio Department: Quote Link to comment Share on other sites More sharing options...
soundslikejustin Posted March 6, 2016 Report Share Posted March 6, 2016 And now for something a little bit different: Not XLRs, but custom low profile RA USB for Zaxnet serial connection. Normal USB connectors end up with bent cable exits from hitting the bottom of the bag. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted March 6, 2016 Report Share Posted March 6, 2016 Justin What connectors are those? Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted March 6, 2016 Report Share Posted March 6, 2016 And now for something a little bit different: Not XLRs, but custom low profile RA USB for Zaxnet serial connection. Normal USB connectors end up with bent cable exits from hitting the bottom of the bag. Oh! Quote Link to comment Share on other sites More sharing options...
Boomboom Posted March 6, 2016 Report Share Posted March 6, 2016 On 2015-12-26 at 11:32 AM, Gene Martin said: We currently don't have them up on the Sound Guys Solutions website, but here are a few pics that I have on me at the moment. Still working on getting colored inserts manufactured, but we've done some custom laser engraved options as well. Would that be possible to get the price for these caps ? Can't find any info about that unfortunately Quote Link to comment Share on other sites More sharing options...
Gene Martin Posted March 6, 2016 Report Share Posted March 6, 2016 Please email me with the quantities and connector type need and we'll get a price to you. gene@audiodept.com Gene Quote Link to comment Share on other sites More sharing options...
