bmfsnd Posted June 14, 2013 Report Share Posted June 14, 2013 In Audition CS6, is there a way to nudge/transport by a single frame? I dived into the menus/keyboard shortcuts but couldn't find a way to do it. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 14, 2013 Report Share Posted June 14, 2013 <old hat> Quote Link to comment Share on other sites More sharing options...
nwstudios Posted June 15, 2013 Report Share Posted June 15, 2013 Still on CS5 but the CS6 manual is here. http://helpx.adobe.com/pdf/audition_reference.pdf Quote Link to comment Share on other sites More sharing options...
ve7kjr Posted June 15, 2013 Report Share Posted June 15, 2013 See if this will work: 5 frames left = alt + shift 5 frames right = alt + shift + 1 frame left = alt + , 1 frame right = alt + . Phil "KJR" Quote Link to comment Share on other sites More sharing options...
ve7kjr Posted June 15, 2013 Report Share Posted June 15, 2013 This works in CS6 and CS5.5 but only in the Multitrack Sessions Keys for mixing multitrack sessions The following keyboard shortcuts apply only in the Multitrack Editor. Result Windows shortcut Mac OS shortcut Select the same input or output for all audio tracks Ctrl+Shift-select Command+Shift-select Activate or deactivate Mute, Solo, Arm For Record, or Monitor Input in all tracks Ctrl+Shift-click Command+Shift-click Adjust knobs in large increments Shift-drag Shift-drag Adjust knobs in small increments Ctrl-drag Command-drag Nudge selected clip to the left Alt+comma Option+comma Nudge selected clip to the right Alt+period Alt+period Maintain keyframe time position or parameter value Shift-drag Shift-drag Reposition envelope segment without creating keyframe Ctrl-drag Command-drag Quote Link to comment Share on other sites More sharing options...
