My new Kortwich 664 custom bag...
pvanstry
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Good question, yes there would be some changes.
Probably not do the CL6 trap panel since the unit is now fully functional without it. Would also make the belt tighter system a bit more aggressive. They don't always hold tight and I have to retighten the belt every hour or so.
Pascal
I got the same belt you did. I just got some tensioners and some extra 2" webbing - I will be adding that to the belt so I can really tighten it up.
http://www.strapworks.com/Plastic_Strap_Adjusters_p/psa.htm
I actually use the Unislot adapter and not the Sony.  The DB25 are really tight in place and hold. I tried modifying the Unislot plate so that i could screw in the DB25 from the cable but it did not work.  I also have velcro on the inside of the bag and velcro on the connectors and it is also holding it in place.
  • 1 month later...
