Arri Amira
  • Replies 183
  • Created
  • Last Reply
Top Posters In This Topic
  • 1 month later...
The extension for slot receivers will accept dual channel receivers, using the Universal multipin connector.
I used it with my SRB.  Works fine.  Only worry is that the slot extension uses a cable that connects underneath the extension box where it is exposed to damage.  Those TAF5 elbows are not very robust.  Another potential issue is that the slot stays powered even when the camera is turned off, so you are constantly draining the camera battery with your hop receiver.  If the cameraperson notices this and shuts down your receiver, it is likely that they will forget to turn it back on when they turn the camera back on.
Brent Calkin
