fieldmixer
Nomad error? *B
Just upgraded to 6.16 from 4.45 I believe.
Reset to factory default first. I've seen this flashing error reported a while back but not for a while. Definitely not since the new software releases. The search is terrible and didn't find too much on google either.
What is this error mean and what it it's purpose. Anyone else on 6.16 still seeing this?
It is a non fatal warning and it is nothing to freak out about - it is generally a card related issue.
If you go to the advanced setup menu and turn on the "Allow Logging" feature. Then nomad will log the *B errors and you can see exactly what is causing the *B
If you upgrade software from a very old version be sure to do the Factory Restore AFTER you install the firmware.
I don't see any warnings on that screen.
I would look at the logging screen just after you see the *B pop up for the first time.
-howy
The screenshot was taken while the "b" icon was coming up every 5-10 seconds. While watching that screen numbers were appearing incrementally at the bottom. 303132333435 etc...
I did the factory reset before install, and installed immediately after.
Anything further I should do?
Hey Howy,
For updates is it okay to load your settings off a CF card AFTER resetting to factory defaults or do you really just need to re-enter all settings manually after update?
Thanks.
No. more efficient for the company, don't bother reception, interrupt programming auto mix, and other magic. And one Answer here could save dozens/hundreds of phone calls slowing every one down. What? Do you have shares in telecom companies? I suggest you start your own board and compulsively moderate there. Please and thank you.
Yes. Read Howy's reply again. He said to do the factory reset after the new firmware was installed.
For updates is it okay to load your settings off a CF card AFTER resetting to factory defaults or do you really just need to re-enter all settings manually after update? .
By re importing the setting brings the possibility of importing some funky setting that you just reset.
I'm not sure if it helps, but once I had this *B type error, a re-format of card (primary and mirror) cured the problem.
I suggest you try first with another newly reformated mirror card, and second newly reformated primary card to see if this is the very reason causes the *B error.
Masaki
I get this error every time I switch between primary folders. I’ve found that if I want to switch folders I need to power down before I record again. This keeps the *B error away.
Evan Meszaros
