Matt Mayer Posted November 22, 2013 Report Share Posted November 22, 2013 The 633 draws ~4-5.5 watts depending on the setup (inputs active, phantom, etc.) A little over 5 watts would be a good rule of thumb. Doing the math a full capacity 71Wh NP-L7s should run the 633 alone a minimum of 12 - 13 hours. Quote Link to comment Share on other sites More sharing options...
Crussell Posted November 22, 2013 Report Share Posted November 22, 2013 Mine are the older NP-L50s. There's a wide range that I'm seeing, doing long haul testing for the last two days, the battery I'm currently running has been in record- 6 tracks for nearly 5 hrs and it's at 14.1v. Also, I should have mentioned that I'm powering a pair of Lectro 401 receivers too. Testing the whole rig, not just the mixer. I'm nearly certain that my batteries are just toast, this one included. Getting the new ones in will hopefully confirm that. I'll probably keep a couple of the not so terrible ones for short SFX recording sessions and around the house testing. Quote Link to comment Share on other sites More sharing options...
aginzo Posted November 22, 2013 Report Share Posted November 22, 2013 If you stopped commenting on every posting you'd have all the time in the world. Eric I don't think that's an option…. Quote Link to comment Share on other sites More sharing options...
aginzo Posted November 22, 2013 Report Share Posted November 22, 2013 Thanks for starting this thread. It looks like a solid machine and if I hadn't already purchased and fell in love with my Nomad I might have considered this option. I've always loved SD products as much as I've loved Zaxcom products. Still wished they'd just added 1 more input with a pre-amp but not like it's a deal breaker they way it is. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted November 22, 2013 Report Share Posted November 22, 2013 I don't think that's an option…. I know that but I figured there was no harm in trying. Eric Quote Link to comment Share on other sites More sharing options...
Crussell Posted November 22, 2013 Report Share Posted November 22, 2013 I know that but I figured there was no harm in trying. Eric keep trying Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted November 23, 2013 Report Share Posted November 23, 2013 The 633 draws ~4-5.5 watts depending on the setup (inputs active, phantom, etc.) A little over 5 watts would be a good rule of thumb. It would be very helpful, Matt, if Sound Devices would include a wattage spec in both the brochure and the manual. Neither have that at the moment. Quote Link to comment Share on other sites More sharing options...
Crussell Posted November 23, 2013 Report Share Posted November 23, 2013 Btw - how long does it run on only AA-batteries? Is that a viable option for powering it or just a back up? Ran it today, 2.5hrs, no phantom powered mics, 6 tracks recording the whole time, on Sanyo Eneloop batteries, freshly charged. Quote Link to comment Share on other sites More sharing options...
Production Houston Posted November 24, 2013 Report Share Posted November 24, 2013 I put my 633 to test for the past few days and discovered its an amazing machine. The faders 4-6 were my biggest concern for the mixer/recorder. Just as others have mentioned the faders are easy to access and use despite their size. I own a 788T which i love. I use the 788T/CL8 with 3 SRB5P in a Deca 601 bag from Petrol on a daily basis, its a tight but nice fit. Everything on the 633 is straightforward, 3 mic/line inputs, 3 line only inputs, stereo XLR outs, 2 TA3 outs, 1/8 out, 1/8 return bus, and wow....10 tracks of recording with timecode. I built the 633 in a 601 bag as well, pretty much a direct swap with the 788T other than some of the interface cables between the SR's and the 633. Its a very nice fit, but since the bag can fit a 788T which I'm used to, it seems like it has a lot of space. I would like a small bag that fits just the recorder and 2 SR receivers, maybe even the Quad pack setup from lectrosonics. The X1, X2 outputs are not capable of mirroring the L/R as they have no matrix capabilities. You have to individually route each track to the output to get a copy of the L/R mix bus. I would like to keep a camera snake in line on the XLR outs and a set of stereo hops using the TA3, this a little tricky at the moment. But being that the 633 is an all digital mixer this could be added with a firmware update. The X3,X4 output matrix is great and would be an awesome tool if they allowed this on the balanced X1, X2 outputs. The X3, X4 outputs have great routing options and can have anything bussed to them, it just happens to be on a stereo 1/8 mini which i don't feel comfortable utilizing for hops....IFB/Comteks are fine. Other than having Ambient Clock It Network capabilities built in and and a way to control the machine via an IOS device as the CL-WI allows with the 788T, this machine is perfect. Great for a throwdown bag, documentary travel kit, and a lot of other scenarios where small and powerful fit the bill. I got 6 hours on 1 NP1, 2 SRB5P receivers, a boom with 48v phantom power the channel, and recording 6 tracks. Its definitely not a replacement for my 788T/CL8 combo but its a killer machine for everything else that doesn't involve the 788T. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted November 24, 2013 Report Share Posted November 24, 2013 Ok I skipped that one: Ambient's ACN inside !?!! Quote Link to comment Share on other sites More sharing options...
Rasmus Wedin Posted November 24, 2013 Report Share Posted November 24, 2013 Ran it today, 2.5hrs, no phantom powered mics, 6 tracks recording the whole time, on Sanyo Eneloop batteries, freshly charged. Thanks man Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted November 24, 2013 Report Share Posted November 24, 2013 Ok I skipped that pne: Ambient's ACN inside !?!! No he did that it was one feature missing that he'd love to have. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted November 24, 2013 Report Share Posted November 24, 2013 Indeed -blushing- Was surprised cause that was a question I was asking myself about the unit and very quick reading about specs during the week, I didn't see it (plus no antenna connector on the box). Printing manual today. Thanks Quote Link to comment Share on other sites More sharing options...
Scotty Audio Tipton Posted November 25, 2013 Report Share Posted November 25, 2013 If this is the wrong discussion list for this inquiry I apologize... My 633 has given me "I/O" errors for my CF card several times now on several gigs. I am using approved media. Delkin CF700X. When it happens, it gives me the error, asks me to select "ok" and then stops recording on the CF card. Each time this has happened the SD card has continued to record - thankfully! I have used several CF cards (both approved and unapproved) and it happened to both. Today I was only recording 5 tracks (poly) and it happened. The first time this happened, the CF slot unnested and didn't recognize ANY CF card until I hard rebooted the machine. I contacted Sound Devices but have heard no reply. It's the weekend. Any insight into this would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
pindrop Posted November 25, 2013 Report Share Posted November 25, 2013 If this is the wrong discussion list for this inquiry I apologize... My 633 has given me "I/O" errors for my CF card several times now on several gigs. I am using approved media. Delkin CF700X. When it happens, it gives me the error, asks me to select "ok" and then stops recording on the CF card. Each time this has happened the SD card has continued to record - thankfully! I have used several CF cards (both approved and unapproved) and it happened to both. Today I was only recording 5 tracks (poly) and it happened. The first time this happened, the CF slot unnested and didn't recognize ANY CF card until I hard rebooted the machine. I contacted Sound Devices but have heard no reply. It's the weekend. Any insight into this would be greatly appreciated. Perhaps try the dedicated Sound Devices forum - http://forums.sounddevices.com/forum/field-mixers/-633-mixer Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted November 25, 2013 Report Share Posted November 25, 2013 I contacted Sound Devices but have heard no reply. It's the weekend. Scotty, Definitely worth a call in to Reedsburg first thing on Monday. The media architecture is pretty much the same as the 664, so its likely you have a hardware problem. Quote Link to comment Share on other sites More sharing options...
Crussell Posted November 25, 2013 Report Share Posted November 25, 2013 Here it is in a Petrol PS614 bag. Figured out how to get it to stand up properly by adjusting the pillows and stuff. The bag is a touch big for it, very compact package. Quote Link to comment Share on other sites More sharing options...
pindrop Posted November 25, 2013 Report Share Posted November 25, 2013 Here it is in a Petrol PS614 bag. Figured out how to get it to stand up properly by adjusting the pillows and stuff. The bag is a touch big for it, very compact package. A quickdraw handle, good idea, I might use a retired one but this one still looks in good nick? Quote Link to comment Share on other sites More sharing options...
Tom Visser Posted November 25, 2013 Report Share Posted November 25, 2013 Scotty, Definitely worth a call in to Reedsburg first thing on Monday. The media architecture is pretty much the same as the 664, so its likely you have a hardware problem. Just a thought, maybe a counterfeit card? Delkin is one of the more popular brands that counter fitters may have marketed? Source of the card? I've been burned in general with some poor Delking products - SanDisk all the way for me now. Quote Link to comment Share on other sites More sharing options...
Crussell Posted November 25, 2013 Report Share Posted November 25, 2013 A quickdraw handle, good idea, I might use a retired one but this one still looks in good nick? Yea I bought it new. I thought it would fit well and it really does. When It's on my harness, it flops out of the way and I use it to clip my headphones to the bag in between takes. It's actually a very useful thing to have around. Quote Link to comment Share on other sites More sharing options...
bmjord Posted November 25, 2013 Report Share Posted November 25, 2013 My 633 has given me "I/O" errors for my CF card several times now on several gigs. I am using approved media. Delkin CF700X. When it happens, it gives me the error, asks me to select "ok" and then stops recording on the CF card. Each time this has happened the SD card has continued to record - thankfully! I have used several CF cards (both approved and unapproved) and it happened to both. Today I was only recording 5 tracks (poly) and it happened. The first time this happened, the CF slot unnested and didn't recognize ANY CF card until I hard rebooted the machine. Me too. I got the 633 on Wednesday. I have used it on three jobs. Mostly just 2 tracks. I got CF I/O errors every day. I have been using the approved Delkin media that came with the kit. I have not had a chance to use other approved media. The SD card has been fine. I have been able to copy to non approved media SD to CF with out any issues. Brian Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted November 25, 2013 Report Share Posted November 25, 2013 Brian, Call or email in to support today. Interested to know what the serial number is of your CF card. Thanks, Matt Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 25, 2013 Report Share Posted November 25, 2013 " Any insight into this would be greatly appreciated. " CRAP happens... Quote Link to comment Share on other sites More sharing options...
Rob Lewis Posted November 25, 2013 Report Share Posted November 25, 2013 Funny, i have never had issues with the Delkin cards. They are my go to cards. Have not tried Delkin CF in my 633 yet. SD 600x 32 delkin seems fine. Quote Link to comment Share on other sites More sharing options...
Sean McCormick Posted November 25, 2013 Report Share Posted November 25, 2013 Had three files out of 17 on an approved 16GB Delkin CF (that's been issue-free on my 664) last Saturday that were unable to transfer to either OSX or Windows 7. Files on SD were fine (thank the Lordy). I received no error messages while recording. Have contacted SD. Quote Link to comment Share on other sites More sharing options...
