jrd456 Posted December 14, 2013 Report Share Posted December 14, 2013 Does the Panasonic AG-AF100 cam change 23.978 to 29.97 when you jam it with 23.978 and if so if I set the cam to 29.97 and use 29.97 to jam it with, does it turn out the same? J.D. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted December 15, 2013 Report Share Posted December 15, 2013 Not sure! Haven't used the AG-AF100. The manual is here: http://www.panasonic.com/business/provideo/includes/pdf/AG-AF100P_OI.pdf I can't cut and paste from the manual (typical restrictive PDF crap), but the instructions are on page 24. Nothing about crossjamming in there -- it seems to say that it can do 23.98 natively (in 1080 or 720). This camera seems to be able to pretty much handle every HD standard. Quote Link to comment Share on other sites More sharing options...
Audio Daddyo Posted December 15, 2013 Report Share Posted December 15, 2013 All the Panasonic cameras I've ever used only accepts or outputs 29.97 Time Code. No matter what the camera is set at. Andy Quote Link to comment Share on other sites More sharing options...
pvanstry Posted December 15, 2013 Report Share Posted December 15, 2013 If you have a 633, 664 or 788, you can return TC out from the camera and go into the jam menu and see the incoming TC frame rate. I do this every shoot I do and set all my devices to that framerate. So far, it always syncs ( except for Final cut error but that has nothing to do with set TC sync ). Quote Link to comment Share on other sites More sharing options...
jrd456 Posted December 15, 2013 Author Report Share Posted December 15, 2013 Actually,not trying to cross-jam.What I'm trying to do is use an old HHB DAT as a time code generator [doesn't have 23.98] with a Panasonic AG-af100 cam., while doing HD .If the cam. changes 23.98 to 29.97 automatically then it should be possible ? I've read the manual,and it isn't clear to me. J.D. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted December 15, 2013 Report Share Posted December 15, 2013 I can't cut and paste from the manual (typical restrictive PDF crap Not to go off topic but.. this online utility can unlock PDF files: http://www.crackmypdf.com/ I've used it many times. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 15, 2013 Report Share Posted December 15, 2013 jrd456: " I've read the manual,and it isn't clear to me. " then try it and see what happens... " .If the cam. changes 23.98 to 29.97 " doubt it, but the rates are compatible, and align on the :00 frame of each second. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 16, 2013 Report Share Posted December 16, 2013 Does the Panasonic AG-AF100 cam change 23.978 to 29.97 when you jam it with 23.978 and if so if I set the cam to 29.97 and use 29.97 to jam it with, does it turn out the same? J.D. This was addressed by myself and others in a recent thread answering your questions about the AF100: Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted December 16, 2013 Report Share Posted December 16, 2013 Not to go off topic but.. this online utility can unlock PDF files: http://www.crackmypdf.com/ I've used it many times. Much appreciated, Rick! I have used the AF100 before and that definitely expects to see 29.97 code. What I'm curious about is whether all these cameras can cross-jam. The last Panasonic Varicam project I did, I asked the editor and she told me they were going to edit it all at 23.98, so I gave them 23.98TC. I never hoid a woid, so I assume all went well. doubt it, but the rates are compatible, and align on the :00 frame of each second. But what if the code doesn't start on a :00 frame? Quote Link to comment Share on other sites More sharing options...
