sounddguy Posted January 17, 2014 Report Share Posted January 17, 2014 If feeding the camera balanced 1/4 inch TRS with an unbalanced signal, should the ring and sleeve be tied together or should either one, and if so which one be left floating? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted January 17, 2014 Report Share Posted January 17, 2014 Tieing the ring & sleeve will unbalance the input. If you're feeding from an XLR then tie pins 1 & 3 in the xlr and just use the tip & sleeve in the TRS. Eric Quote Link to comment Share on other sites More sharing options...
sounddguy Posted January 17, 2014 Author Report Share Posted January 17, 2014 Tieing the ring & sleeve will unbalance the input. If you're feeding from an XLR then tie pins 1 & 3 in the xlr and just use the tip & sleeve in the TRS. Eric I will be feeding scratch off a G-2. Figured I would tie R&S on the Camera end. You gotta love it. Question to DP....which black magic camera will you be shooting? DP - the 2.5k one. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted January 17, 2014 Report Share Posted January 17, 2014 The G2 output is unbalanced (tip & sleeve) on a TRS connector. So the input will be the same. Eric Quote Link to comment Share on other sites More sharing options...
