VASI Posted August 28, 2015 Report Share Posted August 28, 2015 From Aaton Facebook page: Major update for the CantarX3 with firmware 1.71 Main features- Digital filters/EQ on analog inputs- Delay on inputs- Into ingrid, routing of mono post fade (P1..P24)- Into outmaps, highlite a T1..T24 position, press shift+F5 to map post fade (P1..P24)- Backup of a full project- MS decoded or balanced in mixdown- Accurate timecode is maintaibed about 20 minutes in case of Cantar power off. After Cantar power on, a green timecode indicator means the last timecode is still valid.- Tripple shift provide of contextual help (available only in PPR & solo mic for now)- Extended PPR duration (up to 30s at 48kHz)- Remote rec through MDR connector/tally related to fields edit:- Up and down key are available for meta data field navigation- Right key at end of field select next field- Left key at start of field select previous filed- Into edit fields (OK -> validate and select next field)- F4/F6 validate and close the corresponding dialog box- F5 shortcut for take type indicator is available- Shift+ok switch insert/overwrite mode- Update play screen metadata field after edition from play screen using F4 Bug fixes- New management of "lazy" external media (SD/USB)- Line, Aes, Dante out are included into reset factory configuration- Balance lock are saved when power off- Display limiters status- End of play on mixdown and polyphonic files- Desarmed track 11 creates an empty file for this track- Firmware version loader Final design of the CantarX3 bag by Aaton-Digital.Delivery end of September - we take orders The new Cantarem2Available October 2015, we take orders now Quote Link to comment Share on other sites More sharing options...
ao Posted November 9, 2015 Report Share Posted November 9, 2015 software version 1.83 is available from the aaton digital software update page for the x3. the manual has been updated as well to version 1.4 Quote Link to comment Share on other sites More sharing options...
VASI Posted January 6, 2016 Report Share Posted January 6, 2016 From Aaton Digital, Facebook page: Version 1.90 is available for download New in this version - Analog input status (phase inversion , analog filters, and EQ) added at the top of vumeters (for Mics, lines, Aes and Aes42). - Brand new line out and digital out management (see user manual for details). • Delay on line out can be set to up to 22 frames at 24 fps and 48 kHz (in ms of frame). • During playback, line out can be muted or not. • Beep indicator can be enabled or disabled on each line out. • The configuration used on line out can be defined for each position of the main selector. • Press [shift+ok] in LINE OUTMAPS screen to adjust it. • Multiple lineout selection allows quick setup. • Press [shift+arrow] to highlight multiple line out. - Adjustable headphone safety clamping. Adjust your clamping level in relation to the current headphone. Example with -6dB: With your cu rent headphone level, signal over full scale minus 6dB will be clamped into your headset. In PLAY/TEST/PPR/REC main selector position, press [Headphone+Blue] to toggle ON/OFF the clamping function. Yellow headphone icon means ON. [Headphone+Blue+jog] for quick clamping level setup. When the clamp is active on too high signal, headphone audio quality is affected and headphone icon blink in red. - Phase inversion added on AES and AES42 inputs. - EQ capability added on AES and AES42 inputs. These functions are available for digital mics even without smart AES42 communication. - Very low backlight level for night environment. - Contextual help is available in solo dialogs (Line, Mic, AES and AES42). Misc Bug fixes - Update LED when arming/disarming tracks - Family UID correction - Conflict between lock panel and field move in the metadata Edit window. -- My comment: Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted January 6, 2016 Report Share Posted January 6, 2016 Nice that they included a personal message--classy. I had to do a little post work on Christmas--there's what the Sadie onscreen faders looked like on Dec. 25. Quote Link to comment Share on other sites More sharing options...
